Building Audacity 2.3.3 is OK,but recording doesn't work
Building and customizing Audacity from the source code.
auak
Operating System: Windows 7
Post by auak » Sat Apr 25, 2020 5:15 am
Building Audacity 2.3.3 on Windows 7 is successful. i opened a mp3 file, then starting recording, it created a new track to record, when i stopped the recording, it always poped up a dialog
Re: Building Audacity 2.3.3 is OK,but recording doesn't work
Post by steve » Sat Apr 25, 2020 9:26 am
Does the problem only happen with an ASIO build?
auak
Post by auak » Sat Apr 25, 2020 11:05 pm
i downloaded the source, built it without changing anything. however the assert dialog didn't pop up when i opened a mp3 file ,then did append recording.
auak
Post by auak » Sun Apr 26, 2020 12:51 am
the assert dialog doesn't pop up, when i open a mp3 file, then use append record
Post by steve » Sun Apr 26, 2020 12:44 pm
Where did you get the Audacity source code? Do you know the Git revision number?
auak
Post by auak » Mon Apr 27, 2020 10:59 pm
At first,I downloaded the lasted version 2.4. (master) from git, built it. The assert dialog popped up whennever I tried to record on a new track. I thought I might be the problem with the newest version. Then I downloaded audacity 2.3.3 from the tag list. It had the same problem.
Post by steve » Tue Apr 28, 2020 8:52 am
Does the normal official release version of Audacity work for you?
auak
Post by auak » Wed Apr 29, 2020 4:34 am
i installed audacity 2.3.3. and audacity 2.0.0 both on my computer, they all work fine
auak
Post by auak » Sat May 02, 2020 12:35 pm
$ git rev-list --count HEAD
11850
$ git describe --
DarkAudacity-2.1.3x-6005-gffa470124
The assert dialog kept popping up, no matter building the source code by using git clone or downloading a zip directly form github website.
Post by steve » Sat May 02, 2020 12:54 pm
Where did you get that?
The correct GitHub repository for the authentic original Audacity is: https://github.com/audacity/audacity
