Hi
Some users are getting replicable problems with the subject issues in 1.3.5 and CVS HEAD. Can anyone here replicate them, preferably from CVS HEAD?
* This one is quick to check. Click View > History and there is a segmentation fault and Audacity closes without warning. Not dependent on number of items in history. Reported in 1.3.5 Release and CVS (Linux 32-bit, i686, Arch Linux)
* This one takes longer to check. When importing larger WAV files ( > 400 MB) with Preferences set to "read directly", exporting to the same file by overwriting results in a visually/audibly corrupted file. Reported on Debian, both in 1.3.5 and CVS HEAD.
Thanks
View > History and overwriting wave files issues
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
- Quality Assurance
Re: View > History and overwriting wave files issues
I've tested this on Audacity 1.3.5 on Ubuntu 8.04 with no problem.Gale Andrews wrote:* This one is quick to check. Click View > History and there is a segmentation fault and Audacity closes without warning. Not dependent on number of items in history. Reported in 1.3.5 Release and CVS (Linux 32-bit, i686, Arch Linux)
Unable to test it with the CVS version as I can't get it to compile http://audacityteam.org/forum/viewtopic.php?f=19&t=6526 (strange, though, I've not had trouble compiling Audacity 1.3.5, but I don't know how to get past this error.
Sorry, I can't test the other issue as I don't have enough free disk space at the moment.
