no input selector
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
LanceHaverkamp
no input selector
Post by LanceHaverkamp » Wed Sep 24, 2008 11:06 pm
Hello,
Using Mandriva 2008.1 which comes with Audacity 1.3.4. My sound devices (tried 2 different ones) display on the device toolbar, but there is never an input selector. OSS:/dev/dsp records silence, whereas any ALSA setting returns: "Error while opening sound device. Please check the input device settings and the project sample rate." I have disabled pulseaudio. Tried both ALSA & OSS.
Otherwise either soundcard (AC97 on motherboard OR an old, cheap CreativeLabs card) seem to work fine, I can hear a radio plugged into line-in
I've had no trouble with older versions of Audacity in Debian on this same hardware.
Any ideas?
THanks,
Lance
Re: no input selector
Post by steve » Thu Sep 25, 2008 2:48 am
LanceHaverkamp wrote:but there is never an input selector.
You mean in the "Device Toolbar? That's not unusual - I had the same issue with Audacity 1.3.4 in Xubuntu, but selecting the device in "Edit > Preferences > Audio I/O" worked.
Also worth noting that I am finding Audacity 1.3.5 to be a lot more stable on my Linux machine than 1.3.4 was.
Just a thought - it may be worth disabling the on-board sound card in BIOS (or look for a jumper on the motherboard), and just using the SB card.
LanceHaverkamp
Post by LanceHaverkamp » Thu Sep 25, 2008 3:00 am
Yes, I think you call it the device toolbar, but having no input selector makes 1.3.4 totally unusable (at least here). I can either record complete silence on /dev/dsp or not record anything whatsoever under ALSA. Using ALSA all I get is the earlier mentioned error message. I have downgraded to stable, which is not part of Mandriva 2008.1; that fixes the problem. I will look and see if there is a 1.3.5 Mandriva RPM here at the audacity site--Mandriva only distributes 1.3.4 so far.
Thanks,
Lance
