Cannot record streaming on Ubuntu 11.10
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Hi
Got a new PC. installed Oneiric (11.10). Installed Audacity thru the software center tool. It's version 1.3.13-beta. I'm not able to record anything.
I have a bewildering choice in recording device (Edit/preferences/device/recording). I tried various settings one after the other since i'm not sure what I needed.
Everytime when I click record to record some streaming audio the line stays pretty much flat and nothing gets recorded.
I'd appreciate help on deciding which option I should use.
I've also added screens from sound settings which might be of assistance.
Thank you so much.
Thank you so much.
- Attachments
- audacityrecordingsettings.jpg (70.8 KiB) Viewed 5286 times
- SOund settings
- soundsettings.jpg (31.43 KiB) Viewed 5286 times
- hardware input tab on sound settings- using line
- hardwareinput.jpg (30.33 KiB) Viewed 5286 times
Re: Cannot record streaming on Ubuntu 11.10
What application are you trying to record from?
Was that application running (playing) when you made those screenshots?
What options do you have in the hardware input tab on sound settings (third image) in the "connector" settings?
There are instructions for Ubuntu 10.x here: http://wiki.audacityteam.org/wiki/Stere ... _Ubuntu_10
I'm not sure if they can be adapted for Ubuntu 11.x as I don't have that version installed.
Just tried those instructions with Ubuntu 12.04 alpha and with some minor differences the instructions work.steve wrote:I'm not sure if they can be adapted for Ubuntu 11.x as I don't have that version installed.
(but 12.04 is so slow
No, I was trying to record from an Indian music site, it was not playing when I made those screen shots. I've attached the file.steve wrote:What application are you trying to record from?
- Attachments
- HardwareInputTab.jpeg (50.78 KiB) Viewed 5265 times
Sorry, I'm too stupid to follow those instructions, they are way too complex for me. Thanks for pointing me to them anyway. I have a WIndows XP virtual machine in this Linux box and I will use that for recording streaming audio.steve wrote:There are instructions for Ubuntu 10.x here: http://wiki.audacityteam.org/wiki/Stere ... _Ubuntu_10
The most important part is that you install "PulseAudio Volume Control" (also called "pavucontrol").sumithar wrote:Sorry, I'm too stupid to follow those instructions, they are way too complex for me.
If you install that then the instructions will probably make sense - the instructions are pretty detailed (perhaps too much detail) but with pavucontrol installed you may be able to go through them slowly step-by-step. If you get it working once you should find it quite quick and easy the next time. The main problem is that Ubuntu does not install pavucontrol by default.
Once I figured out that Pulse Audio Control is its own app that can be invoked from Unity, things became better. I couldn't tell you the exact sequence of what I did but I finally got Audacity to start working.
Thanks for your patience and working with me.
