[ubuntu 8.04] Sound records normally, playback at 4x speed
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Taladel
Post by Taladel » Mon Aug 04, 2008 5:55 am
Hello.
I've been playing with Audacity for a couple days, using OSS as my sound system with the Creative X-Fi XtremeGamer card.
I've noticed that when I record, the playback is at four times normal speed. I have to slow it down to .25 speed in order to hear it at the regular speed.
Is this just a bug in my config settings, or is something else possibly wrong?
Thanks in advance for the help!
--J
Re: [ubuntu 8.04] Sound records normally, playback at 4x spe
Post by steve » Mon Aug 04, 2008 3:17 pm
Try using ALSA instead of OSS. You may need to fiddle with settings, but "Alsa default" will usually work as long as you select sample rates that are supported by your hardware and driver.
On Xubuntu, I have found Audacity 1.3.5 to work better than 1.3.4 (which I think is still the default for Ubuntu). You can get 1.3.5 from the Ubuntu Intrepid repository.
Taladel
Post by Taladel » Mon Aug 04, 2008 3:55 pm
stevethefiddle wrote:Try using ALSA instead of OSS. You may need to fiddle with settings, but "Alsa default" will usually work as long as you select sample rates that are supported by your hardware and driver.
The problem with that is that ALSA doesn't support my sound card at all, so I'm forced to use OSS to use this card.
Post by steve » Mon Aug 04, 2008 4:06 pm
I think the "Creative X-Fi Xtreme Gamer card" should work with the current version of ALSA on Ubuntu, but it will probably be reported as "Sound Blaster Audigy LS".
