Need Help with Help Manual
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Bryanleeward
Post by Bryanleeward » Mon Jan 24, 2011 12:06 pm
I followed the directions currently available on the Audacity site, quoted here:
1. Download the zipped Manual
2. Extract the zip contents to a folder called "help". Most Windows extraction tools will do this automatically. If your extraction utility produces only a folder called "manual", create a new folder called "help" and place the extracted "manual" folder inside that new "help" folder.
3. Place the help folder in the correct location. On Windows or Mac OS X, it should go inside the folder containing the Audacity program. In an Audacity installation, this would usually be under "Program Files" on Windows, or under "Applications" on Mac OS X.
On Linux, the "help" folder should usually go in /usr/share/audacity if Audacity was installed from a repository package, or /usr/local/share/audacity if you compiled Audacity from our source code.
But when I try to view the Manual on the Help menu in Audacity it says it hasn't been installed.
In step 3. above it says it "...should usually go in /usr/share/audacity" Since that didn't work, are there other locations or steps that are worth trying? I'm using Ubuntu 10.04
Thanks for any help with this.
Re: Need Help with Help Manual
Post by steve » Mon Jan 24, 2011 6:33 pm
It's probably a permissions issue.
If you installed Audacity from the Ubuntu repository (using Synaptic or Ubuntu Software Centre or similar)
Create a folder called "help" in "/usr/share/audacity/" and make yourself the owner with full read/write permissions to that folder.
Then unzip the manual into that folder.
dansynek
Post by dansynek » Sun Jan 30, 2011 5:18 am
I just spent an hour and was close to giving up.
You need to create a directory called help in /usr/share/audacity and then unzip the downloaded zip file there.
I will try to report this as a bug.
Dan
bgravato
Operating System: Linux Debian
Post by bgravato » Sun Jan 30, 2011 11:44 am
dansynek wrote:I just spent an hour and was close to giving up.
Dan
That's the procedure described in the instructions here: http://manual.audacityteam.org/man/Unzipping_the_Manual
What is the bug?
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
