Can I command Audacity from shell?
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
forceoflight
Post by forceoflight » Sat Jan 08, 2011 4:27 pm
Hello,
is it possible to use audacity from the Linux shell? I need a shell script that converts caf file to wav file. Thank you for your answer.
Regards,
FoL
Re: Can I command Audacity from shell?
Post by steve » Sat Jan 08, 2011 6:51 pm
Does Audacity support .CAF files?
bgravato
Operating System: Linux Debian
Post by bgravato » Sun Jan 09, 2011 3:41 am
Audacity is not really the best tool for simply converting file formats... Audacity also doesn't work from the command line. The only thing you can do with audacity from the command line is to launch it, and that it.
For what you want you should have a look at an called pacpl (it's a command line perl script for converting audio formats). pacpl can read CAF.
The syntax is very easy: pacpl --to wav file.caf
It can accept a directoy as input. Read the manpage for more details and examples. You can get pacpl from here: http://pacpl.sourceforge.net/
It's also available in many linux distros such as Debian or Ubuntu.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
forceoflight
Post by forceoflight » Sun Jan 09, 2011 9:36 pm
Hello,
pacpl works perfectly. It took a while to get it compiled and installed to RHEL4 server. Anyway, now it is working and big thanks to you!
Regards,
FoL
