[SOLVED] Using Audacity for Surround Sound?
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
bgravato
Operating System: Linux Debian
Re: Beyond 2 channel-Using Audacity for Surround Sound?
Post by bgravato » Wed Jan 12, 2011 5:08 am
Ok I got ffmpeg working (I had 0.6 and audacity only works with 0.5). I can now successfully import the 48 and 96 files into audacity. The 44 one still fails of course because audacity thinks it's a stereo wav file, which is not. I don't know how to workaround this without changing the file.
Now the funny thing... I can correctly play the 44 and 96 files with mplayer, but it fails to play the 48 file (apparently something about not being able to read the file header correctly).
In VLC I can play all the 3 files correctly...
To sum up, I think the problem is with the files' headers, which seem to be different in all the 3 files. Whether you'll be able to open the files or not looks like will depend on how the program used will read/decode/understand those headers...
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
bgravato
Post by bgravato » Wed Jan 12, 2011 5:20 am
The easiest way I found for being able to open that file with audacity was to use mplayer's dumpaudio to create a new file like this:
Code: Select all
mplayer -dumpaudio -dumpfile newfile.wav xtest-hd_dolby_truehd_channel_check_lossy_5.1_16_44_dts_cd.wav
I could then successfully import newfile.wav into audacity.
