autotune plugin for ubuntu tutorial
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
dageek247
Post by dageek247 » Fri Jan 07, 2011 5:21 pm
I installed Audacity from the ubuntu app center, and i am wondering, where would i find detailed instructions for installing, and using an autotune plugin? i just thought it would be fun to mess with.
any help?
Re: autotune plugin for ubuntu tutorial
Post by steve » Fri Jan 07, 2011 6:35 pm
This is the Audacity 1.2 part of the forum - I think you've probably got Audacity 1.3.12 (look in "Help menu > About Audacity")
Antares Autotune is not available for Linux as far as I'm aware.
dageek247
Post by dageek247 » Fri Jan 07, 2011 7:03 pm
i didnt realise that the Gnu/Linux And Like-Unix forum was for Audacity 1.2.x. you were right, i have Audacity 1.3 beta. could an admin move this thread to where it belongs? i am new to the forums, and i dont know where everthing goes.
i just want to know how to autotune my voice using audacity in ubuntu.
bgravato
Operating System: Linux Debian
Post by bgravato » Fri Jan 07, 2011 7:53 pm
There are two Linux forums, one for audacity 1.2.x and another for audacity 1.3.x (same for the other oses). I moved it to the 1.3 section.
I've never used any autotune plugin before so I can't help with your request sorry.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
dageek247
Post by dageek247 » Fri Jan 07, 2011 8:46 pm
alright, i will post my question in the 1.3.x forums
bgravato
Post by bgravato » Sat Jan 08, 2011 3:18 am
dageek247 wrote:alright, i will post my question in the 1.3.x forums
I already moved this topic to the 1.3.x, no need to post again :)
dageek247
Post by dageek247 » Sat Jan 08, 2011 4:11 pm
So, does any one know how to install an autotune plugin for audacity in ubuntu?
Post by steve » Sat Jan 08, 2011 6:47 pm
There are two (free) options that come to mind:
Autotalent v0.2 http://web.mit.edu/tbaran/www/autotalent.html
It cannot be used in real-time with Audacity, but is fully functional as an "applied" effect.
Unfortunately it is not currently available in the Ubuntu repositories but you can download it from the authors web site.
Unzip the "tar.gz" file and put the "autotalent.so" file into your Audacity plug-ins folder.
Option 2:
The Windows version of Audacity 1.3.12 will run fairly well in WINE http://www.winehq.org/about/
There is a free "auto-tune" (pitch correction) type effect called GSnap (VST plug-in for Windows) http://www.gvst.co.uk/gsnap.htm
I've not tried running it with Audacity in WINE, but I've used it in Windows, so it will probably work.
There are some limitations to using GSnap in Audacity;
Audacity does not support real-time processing, so it can only be used as an "applied" effect.
The graphical display output does not work properly.
The MIDI features are not supported (Audacity does not yet support MIDI other than displaying MIDI files).
dageek247
Post by dageek247 » Mon Jan 10, 2011 3:04 pm
thank you. the first option should be fine.
