1.3.x from command line brings up multiple audacity windows
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
is there some way to disable this? it happens on both cygwin and linux in 1.3.x - it did not happen in 1.2.4
Re: 1.3.x from command line brings up multiple audacity wind
What command are you using to start Audacity?
Are you using a terminal window?
for both linux and cygwin i'm using an Xterm window and just saying "audacity file1.wav file2.wav"stevethefiddle wrote:What command are you using to start Audacity?
so sadly the only way I can get the 1.2.x style single window is to open file1.wav and then use
import function to bring in file2.wav
