stevethefiddle wrote:How are you trying to "clean-up the recording from clicks"? Are you using "Click Removal" or "Noise Removal"?
Both of these effects are "destructive" in the sense that they are making permanent changes to the audio. These effects have to try and guess what is noise and what is music - tweaking the parameters will help the effects "guess" with better accuracy.
For both of these effects you will need to try adjusting the settings to achieve optimum results, and it will require a little experimentation. Try working on a small sample of your recording before applying the effect to the whole track.
Hi there Steve! I used the "Click Removal", and, because I already worked with "wave corrector" under wind before, I knew to be careful. So when I tried to correct a peace of my recording, I made the settings even less sharp then the original settings of audacity, but the effect is in one case zero, when I give just a tiny little bit more effect, the result is disastrous. Only way I found out to correct something, without corrupting the whole file, is to search for the clicks in maximum zoom and correct it by hand, with the pencil-tool, but that's a hell of a job to do for a peace of ¾ of an hour.
I found in the repos of PCLinuxOS the tools GWC and Kwave, which seem to be something like wave-corrector, I'm going to give them a chance. I'll let you hear about it some time.
Paulus
