Recording Stops at 2:35 (SOLVED)
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Desert Sailor
Post by Desert Sailor » Mon Jul 12, 2010 11:45 pm
I really feel like an idiot, but I can not find what I am doing wrong. I have Audacity 1.3.12-beta installed in Ubuntu 10.4. Everything seems to be working properly. I have a ION-USBTT10 turntable and I have it set up so that it records, and I can hear it on play-through just fine.
My problem is when I start the recording everything seems to be working perfectly until 2:35 into the recording. Then it just stops.
Audacity says I have enough disk for 204 hours of recording, but I can't get it to go past 2:35. Any ideas to what I am doing wrong?
Re: Recording Stops at 2:35
Post by Gale Andrews » Tue Jul 13, 2010 2:20 am
Desert Sailor wrote:I really feel like an idiot, but I can not find what I am doing wrong. I have Audacity 1.3.12-beta installed in Ubuntu 10.4. Everything seems to be working properly. I have a ION-USBTT10 turntable and I have it set up so that it records, and I can hear it on play-through just fine.
My problem is when I start the recording everything seems to be working perfectly until 2:35 into the recording. Then it just stops. Audacity says I have enough disk for 204 hours of recording, but I can't get it to go past 2:35. Any ideas to what I am doing wrong?
Try turning off Transport > Software Playthrough to begin with.
Desert Sailor
Post by Desert Sailor » Tue Jul 13, 2010 5:50 pm
That seems to have solved the problem...but it's a pity I can't hear the music as I record it. Minor inconvenience however.
