which A. version for Acer Aspire One?
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Mr. Mike
Post by Mr. Mike » Fri Jun 11, 2010 8:05 pm
Hi
I need to install Audacity on my Acer Aspire One with Linpus Linux. From what I have read in one post here in the forum it seems that for my netbook I need the Linux version Fedora. Is that correct? And which version? Fedora Core or Project?
I want to cut long internet radio streams into peaces. Hope that MP3 support is included.
Any help is appreciated
Mr. Mike
Re: which A. version for Acer Aspire One?
Post by Gale Andrews » Sat Jun 12, 2010 12:15 am
Mr. Mike wrote:Hi
Definitely uninstall Linpus Linux which is nagware and not fully open source. Since Linpus is baased on Fedora you may be better with Fedora than Ubuntu, though Ubuntu is usually thought to be one of the easiest Linux Versions to use. There is some information on Ubuntu and Acer Aspire One here.
The current Fedora version is 13. If you get the latest Fedora 13 you will be able to get the latest Audacity package from Fedora though on Ubuntu you can get a later packaged version of Audacity. Note packages are not supplied by Audacity because we only supply source code for Linux.
I don't know if the Fedora Audacity packages let you encode MP3. To play MP3 on Fedora see this. The Audacity packages on Ubuntu import and export MP3 fine (you have to install LAME to export MP3).
Mr. Mike
Post by Mr. Mike » Thu Jun 24, 2010 7:00 pm
Thanks a lot for this detailed answer! Great!
