suse help wont record or hangs/ intermitant playback
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
subliminalfix
Post by subliminalfix » Tue Apr 27, 2010 1:26 pm
hey people i have been using audacity for about 5 years.recently i bought a new acer aspire laptop and gutted window7 for u/linux
can any one please help me get up and running .i have never had problems with audacity and this is almost painful
i will post dumps or whatever any can help with.
remember im new to linux so you may need to explain step by step.
also if anyone knows a stable or operative platfom version or kernal to goto i just need audacity to funtion.
heres what i know now.(granted im a user not a dev/programmer)
when i change the internal preference from pulse to alsa i either get no recording just hangs or records for 7-12 seconds and freezes
im using suse 11.2 and audacity version1.3.11
heres some system stuff i have been able to figure out hopefully it may help
Default capture device number: 1
Default playback device number: 1
Device ID: 0
Device name: ALSA: pulse
Input channels: 32
Output channels: 32
Low Input Latency: 0.011610
Low Output Latency: 0.011610
High Input Latency: 0.046440
High Output Latency: 0.046440
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Device ID: 1
Device name: ALSA: default
Input channels: 128
Output channels: 128
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Device ID: 2
Device name: JACK Audio Connection Kit: system
Input channels: 2
Output channels: 2
Low Input Latency: 0.021333
Low Output Latency: 0.021333
High Input Latency: 0.021333
High Output Latency: 0.021333
Supported Rates:
48000
Selected capture device: 0 - ALSA: pulse
Selected playback device: 0 - ALSA: pulse
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Unable to open Portmixer
Using 57260 chunks of 293 samples each, for a total of 32.0 MB.
Preparing...
Performing 100 edits...
Cut: 5840076 - 14108243
Paste: 68855
Cut: 16271169 - 16541022
Paste: 9809640
Cut: 15814382 - 16768390
Paste: 11413815
Cut: 287140 - 5788215
Paste: 1096406
Cut: 15954436 - 16468651
Paste: 14315394
Cut: 5728443 - 6561735
Paste: 14710944
Cut: 10173546 - 12582299
Paste: 4433383
Cut: 331676 - 6111980
Paste: 5361021
Cut: 9354318 - 14245367
Paste: 4077388
Cut: 3313537 - 13605748
Paste: 1408451
Cut: 7066867 - 9088567
Paste: 3021709
Cut: 5861758 - 13384826
Paste: 8409979
Cut: 6351361 - 16748759
Paste: 6289538
Cut: 11641769 - 15382500
Paste: 11233327
Cut: 10550930 - 13545390
Paste: 4932948
Cut: 7245890 - 9332050
Paste: 1019933
Cut: 15037346 - 16371082
Paste: 7269623
Cut: 11079795 - 13445477
Paste: 14355828
Cut: 14802653 - 15413265
Paste: 1771185
Cut: 5998882 - 8851237
Paste: 3895728
Cut: 1048940 - 14632420
Paste: 627899
Cut: 10832796 - 14028254
Paste: 13444305
Cut: 7633236 - 13774809
Paste: 2970141
Cut: 12688658 - 15576173
Paste: 13223090
Cut: 13727636 - 13759866
Paste: 3879027
Cut: 10477387 - 14045834
Paste: 2990944
Cut: 10619492 - 11882908
Paste: 13396839
Cut: 1342233 - 2870521
Paste: 14947688
Cut: 5687716 - 16078961
Paste: 2918280
Cut: 5136583 - 15719157
Paste: 2102568
Cut: 4353687 - 9606298
Paste: 2894547
Cut: 13476828 - 13814071
Paste: 9359006
Cut: 2388536 - 8921850
Paste: 3402902
Cut: 6882570 - 9192289
Paste: 9020005
Cut: 6853563 - 14221341
Paste: 5812241
Cut: 14011260 - 14070153
Paste: 3337270
Cut: 3361296 - 9583444
Paste: 3283944
Cut: 13206975 - 15041155
Paste: 5333772
Cut: 541171 - 8144521
Paste: 7019694
Cut: 4192830 - 9087102
Paste: 5643766
Cut: 12617752 - 13911347
Paste: 12492641
Cut: 6937947 - 14126409
Paste: 7192564
Cut: 12151589 - 16495900
Paste: 11504352
Cut: 7105250 - 15414144
Paste: 3904518
Cut: 5713207 - 10208413
Paste: 7571413
Cut: 8003295 - 8072150
Paste: 9943834
Cut: 10801738 - 14569132
Paste: 12991327
Cut: 7582254 - 13750197
Paste: 420748
Cut: 8375698 - 13315678
Paste: 6534486
Cut: 3033136 - 9117281
Paste: 883102
Cut: 2811628 - 4093503
Paste: 8642328
Cut: 5269312 - 9185550
Paste: 5756571
Cut: 12338523 - 14969956
Paste: 885153
Cut: 15781859 - 16388076
Paste: 4424593
Cut: 1866410 - 5435736
Paste: 10943257
Cut: 6946737 - 15028849
Paste: 5759794
Cut: 15081003 - 15122609
Paste: 10627403
Cut: 9205474 - 10807012
Paste: 13201994
Cut: 15783617 - 15972602
Paste: 14703912
Cut: 5724634 - 10921282
Paste: 1606812
Cut: 7116677 - 7907484
Paste: 5709984
Cut: 7481462 - 13716502
Paste: 3841230
Cut: 5555573 - 15403303
Paste: 1581907
Cut: 9531876 - 13573518
Paste: 33109
Cut: 1563448 - 7809622
Paste: 9136912
Cut: 15027677 - 16139026
Paste: 11451612
Cut: 309115 - 8360755
Paste: 6024959
Cut: 3032257 - 3888110
Paste: 4910094
Cut: 8264944 - 10165049
Paste: 2811042
Cut: 3991832 - 15499407
Paste: 4518060
Cut: 3908034 - 13025315
Paste: 5837732
Cut: 2345465 - 7728754
Paste: 7708244
Cut: 2654287 - 14419409
Paste: 4297431
Cut: 15795923 - 16328011
Paste: 4465320
Cut: 11358731 - 14278769
Paste: 2898942
Cut: 16541022 - 16766046
Paste: 9043445
Cut: 3767980 - 4183161
Paste: 14403880
Cut: 8369545 - 13865932
Paste: 3419896
Cut: 10657582 - 15387774
Paste: 9576119
Cut: 2051586 - 7299802
Paste: 592446
Cut: 15967621 - 16025928
Paste: 6034628
Cut: 12018567 - 14200538
Paste: 10835140
Cut: 11663158 - 13214300
Paste: 12054606
Cut: 2910955 - 16442867
Paste: 564611
Cut: 5596593 - 13710056
Paste: 4809009
Cut: 14339127 - 14673440
Paste: 5782062
Cut: 10088576 - 15367557
Paste: 5103474
Cut: 3979233 - 8078303
Paste: 10525439
Cut: 15705093 - 15832548
Paste: 611198
Cut: 15145170 - 16428510
Paste: 414888
Cut: 967193 - 10003313
Paste: 430417
Cut: 15067525 - 16408000
Paste: 14693657
Cut: 13402699 - 15971137
Paste: 2212736
Cut: 9416727 - 15978462
Paste: 1696177
Cut: 4717886 - 16657929
Paste: 2898356
Cut: 9259972 - 13006856
Paste: 6182007
Cut: 10649085 - 11724395
Paste: 15139310
Cut: 13938596 - 15771604
Paste: 12711219
Cut: 3205420 - 11802333
Paste: 7924771
Cut: 8288677 - 9888164
Paste: 4831570
Block 0: start 0 len 32768 refs 1 e00002c9.au
Block 1: start 32768 len 24545 refs 1 e00041f2.au
Block 2: start 57313 len 24545 refs 1 e00040d8.au
Block 3: start 81858 len 32768 refs 19 e000170d.au
Block 4: start 114626 len 32768 refs 19 e00013e8.au
Block 5: start 147394 len 32768 refs 19 e000183b.au
Block 6: start 180162 len 21695 refs 6 e000306c.au
Block 7: start 201857 len 21696 refs 6 e0003c7b.au
Block 8: start 223553 len 20516 refs 3 e0004cd8.au
Block 9: start 244069 len 17327 refs 3 e0004d97.au
Block 10: start 261396 len 17327 refs 3 e0004cfd.au
Block 11: start 278723 len 30392 refs 1 e000473e.au
Block 12: start 309115 len 21987 refs 1 e00043f8.au
Block 13: start 331102 len 32768 refs 18 e00004ae.au
Block 14: start 363870 len 21993 refs 18 e00024eb.au
Block 15: start 385863 len 21993 refs 18 e000261b.au
Block 16: start 407856 len 26149 refs 1 e0005c8d.au
Block 17: start 434005 len 26150 refs 1 e00053ae.au
Block 18: start 460155 len 26150 refs 1 e00054df.au
Block 19: start 486305 len 18241 refs 22 e00023f9.au
Block 20: start 504546 len 19793 refs 22 e0001e44.au
Block 21: start 524339 len 19793 refs 22 e0002542.au
Block 22: start 544132 len 21358 refs 3 e000520f.au
Block 23: start 565490 len 18144 refs 3 e00052e6.au
Block 24: start 583634 len 18145 refs 3 e0005122.au
Block 25: start 601779 len 32768 refs 18 e0001c97.au
Block 26: start 634547 len 32768 refs 18 e00011bc.au
Block 27: start 667315 len 24720 refs 5 e000414c.au
Block 28: start 692035 len 24720 refs 5 e0004949.au
Block 29: start 716755 len 32768 refs 27 e0000d3c.au
Block 30: start 749523 len 32768 refs 27 e00004ad.au
Block 31: start 782291 len 31466 refs 26 e000206d.au
Block 32: start 813757 len 30962 refs 25 e000280a.au
Block 33: start 844719 len 16903 refs 25 e0002061.au
Block 34: start 861622 len 16904 refs 25 e0002d81.au
Block 35: start 878526 len 16498 refs 23 e0002e17.au
Block 36: start 895024 len 22723 refs 18 e0003b63.au
Block 37: start 917747 len 22724 refs 18 e0003659.au
Block 38: start 940471 len 32768 refs 20 e00009bb.au
Block 39: start 973239 len 21905 refs 14 e0003651.au
Block 40: start 995144 len 27026 refs 9 e0004e6a.au
Block 41: start 1022170 len 27027 refs 9 e0004167.au
Block 42: start 1049197 len 22006 refs 24 e0002373.au
Block 43: start 1071203 len 26122 refs 17 e00037d7.au
Block 44: start 1097325 len 26122 refs 17 e0003f03.au
Block 45: start 1123447 len 25827 refs 2 e0005326.au
Block 46: start 1149274 len 25828 refs 2 e0005aa7.au
Block 47: start 1175102 len 20683 refs 19 e00003ca.au
Block 48: start 1195785 len 32768 refs 19 e00001d4.au
Block 49: start 1228553 len 32768 refs 19 e00004c5.au
Block 50: start 1261321 len 32768 refs 19 e0000374.au
Block 51: start 1294089 len 28191 refs 2 e00044e5.au
Block 52: start 1322280 len 28192 refs 2 e000440d.au
Block 53: start 1350472 len 29705 refs 2 e0005a29.au
Block 54: start 1380177 len 29705 refs 2 e0005939.au
Block 55: start 1409882 len 31193 refs 5 e0003440.au
Block 56: start 1441075 len 23206 refs 2 e00059d3.au
Block 57: start 1464281 len 23207 refs 2 e000573c.au
Block 58: start 1487488 len 23207 refs 2 e0005770.au
Block 59: start 1510695 len 32768 refs 32 e000154a.au
Block 60: start 1543463 len 29391 refs 15 e00030f5.au
Block 61: start 1572854 len 29897 refs 10 e00041f9.au
Block 62: start 1602751 len 29898 refs 10 e00049c4.au
Block 63: start 1632649 len 17527 refs 10 e00042ca.au
Block 64: start 1650176 len 24167 refs 10 e0004aed.au
Block 65: start 1674343 len 25038 refs 1 e00058c7.au
Block 66: start 1699381 len 25039 refs 1 e00057d0.au
Block 67: start 1724420 len 21860 refs 28 e000215e.au
Block 68: start 1746280 len 29883 refs 28 e00021af.au
Block 69: start 1776163 len 32768 refs 33 e0001411.au
Block 70: start 1808931 len 32768 refs 33 e000198b.au
Block 71: start 1841699 len 29152 refs 30 e000240e.au
Block 72: start 1870851 len 29152 refs 30 e0002e53.au
Block 73: start 1900003 len 29153 refs 30 e0002e50.au
Block 74: start 1929156 len 32768 refs 30 e000020c.au
Block 75: start 1961924 len 29741 refs 3 e0004115.au
Block 76: start 1991665 len 29742 refs 3 e000437b.au
Block 77: start 2021407 len 20600 refs 19 e0002376.au
Block 78: start 2042007 len 32768 refs 22 e0001b82.au
Block 79: start 2074775 len 32768 refs 22 e0001798.au
Block 80: start 2107543 len 24246 refs 19 e000203c.au
Block 81: start 2131789 len 31405 refs 19 e00022f9.au
Block 82: start 2163194 len 31406 refs 19 e0002f50.au
Block 83: start 2194600 len 32768 refs 24 e0000251.au
Block 84: start 2227368 len 32768 refs 24 e00001db.au
Block 85: start 2260136 len 32768 refs 24 e000038e.au
Block 86: start 2292904 len 27060 refs 24 e0002570.au
Block 87: start 2319964 len 27060 refs 24 e00027c8.au
Block 88: start 2347024 len 27061 refs 24 e0002554.au
Block 89: start 2374085 len 32768 refs 26 e000165b.au
Block 90: start 2406853 len 32768 refs 26 e0001599.au
Block 91: start 2439621 len 32768 refs 26 e00018b1.au
Block 92: start 2472389 len 32768 refs 26 e00013e2.au
Block 93: start 2505157 len 32768 refs 26 e0001dc4.au
Block 94: start 2537925 len 32768 refs 26 e00011cd.au
Block 95: start 2570693 len 32768 refs 26 e0001c6d.au
Block 96: start 2603461 len 32768 refs 26 e0001d01.au
Block 97: start 2636229 len 32768 refs 26 e000120e.au
Block 98: start 2668997 len 24097 refs 3 e0004f52.au
Block 99: start 2693094 len 24098 refs 3 e0004063.au
Block 100: start 2717192 len 24098 refs 3 e000441b.au
Block 101: start 2741290 len 21700 refs 5 e000475d.au
Block 102: start 2762990 len 21987 refs 5 e000420e.au
Block 103: start 2784977 len 21987 refs 5 e0004d25.au
Block 104: start 2806964 len 32768 refs 16 e0001c5b.au
Block 105: start 2839732 len 19789 refs 8 e0004dfa.au
Block 106: start 2859521 len 19790 refs 8 e0004b16.au
Block 107: start 2879311 len 23459 refs 1 e0005553.au
Block 108: start 2902770 len 23459 refs 1 e0005d60.au
Block 109: start 2926229 len 23460 refs 1 e0005bd3.au
Block 110: start 2949689 len 19783 refs 5 e0004098.au
Block 111: start 2969472 len 19783 refs 5 e0004b31.au
Block 112: start 2989255 len 21208 refs 3 e000503d.au
Block 113: start 3010463 len 21208 refs 3 e00056a4.au
Block 114: start 3031671 len 16765 refs 3 e0005a7e.au
Block 115: start 3048436 len 16765 refs 3 e00050c7.au
Block 116: start 3065201 len 25479 refs 19 e000276c.au
Block 117: start 3090680 len 32768 refs 26 e0001578.au
Block 118: start 3123448 len 24630 refs 12 e0003ba5.au
Block 119: start 3148078 len 24631 refs 12 e0003c07.au
Block 120: start 3172709 len 32711 refs 1 e00050d6.au
Block 121: start 3205420 len 16898 refs 1 e00054f2.au
Block 122: start 3222318 len 22172 refs 14 e0003e11.au
Block 123: start 3244490 len 25337 refs 4 e0005f47.au
Block 124: start 3269827 len 25337 refs 4 e000523f.au
Block 125: start 3295164 len 19734 refs 1 e0005e5c.au
Block 126: start 3314898 len 19735 refs 1 e00050cb.au
Block 127: start 3334633 len 18567 refs 1 e0005781.au
Block 128: start 3353200 len 18568 refs 1 e0005088.au
Block 129: start 3371768 len 32768 refs 27 e00002e2.au
Block 130: start 3404536 len 26912 refs 16 e00026c4.au
Block 131: start 3431448 len 20594 refs 4 e0004acd.au
Block 132: start 3452042 len 20594 refs 4 e0004bc9.au
Block 133: start 3472636 len 22561 refs 4 e0004d2e.au
Block 134: start 3495197 len 32705 refs 15 e00032b9.au
Block 135: start 3527902 len 32768 refs 25 e000197a.au
Block 136: start 3560670 len 32768 refs 25 e0001c0c.au
Block 137: start 3593438 len 32768 refs 25 e0001896.au
Block 138: start 3626206 len 32768 refs 25 e0001574.au
Block 139: start 3658974 len 32768 refs 25 e0001e34.au
Block 140: start 3691742 len 23357 refs 16 e0003270.au
Block 141: start 3715099 len 23357 refs 16 e00035a3.au
Block 142: start 3738456 len 29705 refs 10 e0004c6c.au
Block 143: start 3768161 len 29705 refs 10 e0004499.au
Block 144: start 3797866 len 19338 refs 20 e0002426.au
Block 145: start 3817204 len 21389 refs 13 e000342e.au
Block 146: start 3838593 len 18096 refs 4 e0004b07.au
Block 147: start 3856689 len 18096 refs 4 e00045d0.au
Block 148: start 3874785 len 31159 refs 4 e0004e03.au
Block 149: start 3905944 len 31160 refs 4 e000496a.au
Block 150: start 3937104 len 32768 refs 24 e0000a23.au
Block 151: start 3969872 len 32768 refs 24 e0000fc3.au
Block 152: start 4002640 len 32768 refs 24 e0000d6a.au
Block 153: start 4035408 len 32768 refs 24 e000033a.au
Block 154: start 4068176 len 16765 refs 4 e000477e.au
Block 155: start 4084941 len 16766 refs 4 e0004124.au
Block 156: start 4101707 len 21833 refs 1 e0005a05.au
Block 157: start 4123540 len 21834 refs 1 e00050e8.au
Block 158: start 4145374 len 32768 refs 28 e0001f42.au
Block 159: start 4178142 len 32768 refs 28 e0001d11.au
Block 160: start 4210910 len 16787 refs 11 e00043d3.au
Block 161: start 4227697 len 17490 refs 11 e00044ab.au
Block 162: start 4245187 len 17490 refs 11 e00043ff.au
Block 163: start 4262677 len 32768 refs 30 e0000b6c.au
Block 164: start 4295445 len 32768 refs 30 e00005d5.au
Block 165: start 4328213 len 29973 refs 11 e0004af3.au
Block 166: start 4358186 len 29973 refs 11 e00049a1.au
Block 167: start 4388159 len 32768 refs 24 e00009c8.au
Block 168: start 4420927 len 23330 refs 12 e00041d8.au
Block 169: start 4444257 len 21063 refs 6 e0004731.au
Block 170: start 4465320 len 21073 refs 6 e0004c08.au
Block 171: start 4486393 len 21073 refs 6 e0004ae8.au
Block 172: start 4507466 len 32768 refs 28 e0000f92.au
Block 173: start 4540234 len 32768 refs 28 e0000008.au
Block 174: start 4573002 len 32768 refs 28 e00000bf.au
Block 175: start 4605770 len 32768 refs 28 e000030f.au
Block 176: start 4638538 len 32768 refs 28 e00009b2.au
Block 177: start 4671306 len 32768 refs 28 e000018d.au
Block 178: start 4704074 len 32768 refs 28 e00009d7.au
Block 179: start 4736842 len 32768 refs 28 e0000912.au
Block 180: start 4769610 len 31970 refs 6 e00048c9.au
Block 181: start 4801580 len 31710 refs 1 e0005916.au
Block 182: start 4833290 len 31710 refs 1 e0005dcf.au
Block 183: start 4865000 len 21068 refs 20 e0002718.au
Block 184: start 4886068 len 23939 refs 20 e0002330.au
Block 185: start 4910007 len 30151 refs 7 e0004708.au
Block 186: start 4940158 len 30151 refs 7 e0004cbd.au
Block 187: start 4970309 len 32768 refs 14 e00003cc.au
Block 188: start 5003077 len 32768 refs 14 e00005d9.au
Block 189: start 5035845 len 32768 refs 14 e00006ca.au
Block 190: start 5068613 len 32768 refs 14 e0000b9e.au
Block 191: start 5101381 len 29049 refs 13 e0002649.au
Block 192: start 5130430 len 20218 refs 13 e00024b1.au
Block 193: start 5150648 len 24318 refs 13 e0002b18.au
Block 194: start 5174966 len 17857 refs 13 e0002099.au
Block 195: start 5192823 len 32768 refs 14 e0000b6b.au
Block 196: start 5225591 len 32768 refs 14 e0000c99.au
Block 197: start 5258359 len 30580 refs 13 e0003d10.au
Block 198: start 5288939 len 30580 refs 13 e0003bb9.au
Block 199: start 5319519 len 32768 refs 29 e00000f9.au
Block 200: start 5352287 len 32768 refs 29 e00001b1.au
Block 201: start 5385055 len 32768 refs 29 e0000750.au
Block 202: start 5417823 len 32768 refs 29 e00003b2.au
Block 203: start 5450591 len 32768 refs 29 e00004a2.au
Block 204: start 5483359 len 32768 refs 29 e0000828.au
Block 205: start 5516127 len 32768 refs 29 e0000385.au
Block 206: start 5548895 len 32768 refs 29 e0000f0f.au
Block 207: start 5581663 len 32768 refs 29 e0000d12.au
Block 208: start 5614431 len 32768 refs 29 e0000697.au
Block 209: start 5647199 len 18940 refs 14 e0003dbb.au
Block 210: start 5666139 len 18940 refs 14 e0003ffe.au
Block 211: start 5685079 len 17695 refs 14 e0003ac6.au
Block 212: start 5702774 len 19134 refs 9 e0004fff.au
Block 213: start 5721908 len 22943 refs 7 e00040a0.au
Block 214: start 5744851 len 22153 refs 7 e0004680.au
Block 215: start 5767004 len 22153 refs 7 e0004c8e.au
Block 216: start 5789157 len 25157 refs 20 e0002e78.au
Block 217: start 5814314 len 32768 refs 21 e0001670.au
Block 218: start 5847082 len 22371 refs 15 e0002fbe.au
Block 219: start 5869453 len 22372 refs 15 e000224d.au
Block 220: start 5891825 len 22372 refs 15 e0002349.au
Block 221: start 5914197 len 22565 refs 8 e0004117.au
Block 222: start 5936762 len 22565 refs 8 e0004aec.au
Block 223: start 5959327 len 28288 refs 11 e0004dc4.au
Block 224: start 5987615 len 17171 refs 8 e0004f3a.au
Block 225: start 6004786 len 17172 refs 8 e0004d70.au
Block 226: start 6021958 len 32768 refs 30 e0000f36.au
Block 227: start 6054726 len 22767 refs 26 e0002563.au
Block 228: start 6077493 len 22767 refs 26 e0002085.au
Block 229: start 6100260 len 20640 refs 26 e0002b0b.au
Block 230: start 6120900 len 29692 refs 7 e000446e.au
Block 231: start 6150592 len 29692 refs 7 e0004253.au
Block 232: start 6180284 len 22973 refs 16 e0003e73.au
Block 233: start 6203257 len 22974 refs 16 e00034d3.au
Block 234: start 6226231 len 31956 refs 5 e0005bdf.au
Block 235: start 6258187 len 20031 refs 20 e000250a.au
Block 236: start 6278218 len 30220 refs 7 e0004c32.au
Block 237: start 6308438 len 30221 refs 7 e0004f47.au
Block 238: start 6338659 len 32768 refs 29 e000007a.au
Block 239: start 6371427 len 30805 refs 1 e000552a.au
Block 240: start 6402232 len 30806 refs 1 e0005250.au
Block 241: start 6433038 len 26383 refs 15 e0004b42.au
Block 242: start 6459421 len 26383 refs 15 e00048b7.au
Block 243: start 6485804 len 26383 refs 15 e0004109.au
Block 244: start 6512187 len 32768 refs 34 e0000042.au
Block 245: start 6544955 len 19524 refs 29 e0002f84.au
Block 246: start 6564479 len 19524 refs 29 e0002f14.au
Block 247: start 6584003 len 17319 refs 29 e0002e2f.au
Block 248: start 6601322 len 18587 refs 7 e0004893.au
Block 249: start 6619909 len 21961 refs 11 e00040f1.au
Block 250: start 6641870 len 21962 refs 11 e0004a66.au
Block 251: start 6663832 len 21962 refs 11 e0004fb0.au
Block 252: start 6685794 len 17924 refs 14 e00036b8.au
Block 253: start 6703718 len 26133 refs 14 e0003939.au
Block 254: start 6729851 len 26134 refs 14 e000346c.au
Block 255: start 6755985 len 32768 refs 30 e0000d40.au
Block 256: start 6788753 len 32768 refs 30 e0000c71.au
Block 257: start 6821521 len 32768 refs 30 e00008d7.au
Block 258: start 6854289 len 26594 refs 7 e0004684.au
Block 259: start 6880883 len 26595 refs 7 e00041f5.au
Block 260: start 6907478 len 23607 refs 2 e0005e06.au
Block 261: start 6931085 len 23607 refs 2 e0005ef8.au
Block 262: start 6954692 len 23506 refs 4 e000540f.au
Block 263: start 6978198 len 23506 refs 4 e0005163.au
Block 264: start 7001704 len 23507 refs 4 e0005b90.au
Block 265: start 7025211 len 22246 refs 34 e0002214.au
Block 266: start 7047457 len 25563 refs 16 e0004feb.au
Block 267: start 7073020 len 17367 refs 16 e0004aa8.au
Block 268: start 7090387 len 17367 refs 16 e00041e8.au
Block 269: start 7107754 len 31789 refs 10 e0004b85.au
Block 270: start 7139543 len 31790 refs 10 e0004a50.au
Block 271: start 7171333 len 32768 refs 27 e0001f69.au
Block 272: start 7204101 len 32768 refs 27 e00014e7.au
Block 273: start 7236869 len 32768 refs 27 e0001a60.au
Block 274: start 7269637 len 26649 refs 15 e0003380.au
Block 275: start 7296286 len 18642 refs 15 e000331d.au
Block 276: start 7314928 len 17808 refs 9 e0004280.au
Block 277: start 7332736 len 17809 refs 9 e00045ef.au
Block 278: start 7350545 len 27161 refs 10 e0004b3c.au
Block 279: start 7377706 len 27161 refs 10 e00047b9.au
Block 280: start 7404867 len 32768 refs 27 e0000a54.au
Block 281: start 7437635 len 32768 refs 27 e00009ae.au
Block 282: start 7470403 len 32768 refs 27 e0000413.au
Block 283: start 7503171 len 23731 refs 1 e000505d.au
Block 284: start 7526902 len 23731 refs 1 e0005a1e.au
Block 285: start 7550633 len 16431 refs 4 e0004d6e.au
Block 286: start 7567064 len 20757 refs 5 e0004545.au
Block 287: start 7587821 len 22035 refs 5 e0004c3e.au
Block 288: start 7609856 len 22036 refs 5 e0004e16.au
Block 289: start 7631892 len 17519 refs 10 e0003366.au
Block 290: start 7649411 len 17520 refs 10 e000346d.au
Block 291: start 7666931 len 17609 refs 10 e000353a.au
Block 292: start 7684540 len 17610 refs 10 e0003079.au
Block 293: start 7702150 len 32768 refs 31 e00007f3.au
Block 294: start 7734918 len 32768 refs 31 e0000a28.au
Block 295: start 7767686 len 32768 refs 31 e00002a8.au
Block 296: start 7800454 len 23561 refs 5 e000434e.au
Block 297: start 7824015 len 23561 refs 5 e00045e5.au
Block 298: start 7847576 len 23562 refs 5 e0004d15.au
Block 299: start 7871138 len 24326 refs 8 e000455e.au
Block 300: start 7895464 len 23740 refs 2 e00053b2.au
Block 301: start 7919204 len 27437 refs 2 e0005246.au
Block 302: start 7946641 len 28492 refs 2 e00054d9.au
Block 303: start 7975133 len 28492 refs 2 e0005d76.au
Block 304: start 8003625 len 32768 refs 22 e00014a3.au
Block 305: start 8036393 len 28708 refs 20 e0002110.au
Block 306: start 8065101 len 28708 refs 20 e0002a71.au
Block 307: start 8093809 len 25147 refs 11 e0004127.au
Block 308: start 8118956 len 25148 refs 11 e0004e84.au
Block 309: start 8144104 len 25148 refs 11 e0004176.au
Block 310: start 8169252 len 32768 refs 32 e0001b3d.au
Block 311: start 8202020 len 32768 refs 32 e00012d5.au
Block 312: start 8234788 len 21231 refs 9 e00047c7.au
Block 313: start 8256019 len 21231 refs 9 e0004e29.au
Block 314: start 8277250 len 21511 refs 19 e00030ea.au
Block 315: start 8298761 len 24197 refs 10 e000484c.au
Block 316: start 8322958 len 25784 refs 2 e0005951.au
Block 317: start 8348742 len 20510 refs 2 e000563e.au
Block 318: start 8369252 len 18573 refs 2 e0005e26.au
Block 319: start 8387825 len 18573 refs 2 e00056e7.au
Block 320: start 8406398 len 32768 refs 19 e00019e4.au
Block 321: start 8439166 len 32768 refs 19 e000126e.au
Block 322: start 8471934 len 21843 refs 2 e00041da.au
Block 323: start 8493777 len 27925 refs 2 e000462f.au
Block 324: start 8521702 len 32140 refs 2 e0003eaa.au
Block 325: start 8553842 len 16452 refs 2 e0003eba.au
Block 326: start 8570294 len 29819 refs 1 e000504f.au
Block 327: start 8600113 len 23539 refs 10 e00034e5.au
Block 328: start 8623652 len 32768 refs 18 e00010ad.au
Block 329: start 8656420 len 26478 refs 11 e0003df0.au
Block 330: start 8682898 len 26747 refs 3 e000425d.au
Block 331: start 8709645 len 26748 refs 3 e0004409.au
Block 332: start 8736393 len 18892 refs 1 e0005178.au
Block 333: start 8755285 len 18893 refs 1 e000593a.au
Block 334: start 8774178 len 21906 refs 1 e0005967.au
Block 335: start 8796084 len 26732 refs 22 e00021c7.au
Block 336: start 8822816 len 31756 refs 10 e0004dc9.au
Block 337: start 8854572 len 31757 refs 10 e0004c72.au
Block 338: start 8886329 len 23083 refs 25 e0002cb5.au
Block 339: start 8909412 len 23279 refs 10 e0004efb.au
Block 340: start 8932691 len 25321 refs 10 e000491d.au
Block 341: start 8958012 len 26148 refs 18 e0002407.au
Block 342: start 8984160 len 26148 refs 18 e0002868.au
Block 343: start 9010308 len 26149 refs 18 e0002b57.au
Block 344: start 9036457 len 23711 refs 18 e000265a.au
Block 345: start 9060168 len 28332 refs 17 e000236b.au
Block 346: start 9088500 len 22437 refs 9 e00043e0.au
Block 347: start 9110937 len 22438 refs 9 e0004f16.au
Block 348: start 9133375 len 31372 refs 8 e00040eb.au
Block 349: start 9164747 len 23857 refs 1 e0005e2f.au
Block 350: start 9188604 len 23857 refs 1 e00058ac.au
Block 351: start 9212461 len 23857 refs 1 e00053af.au
Block 352: start 9236318 len 26154 refs 2 e0005dd8.au
Block 353: start 9262472 len 27992 refs 2 e0004931.au
Block 354: start 9290464 len 18240 refs 8 e00041f7.au
Block 355: start 9308704 len 18240 refs 8 e0004492.au
Block 356: start 9326944 len 24136 refs 21 e0002a80.au
Block 357: start 9351080 len 24137 refs 21 e00028b3.au
Block 358: start 9375217 len 32768 refs 23 e00013ff.au
Block 359: start 9407985 len 32768 refs 23 e00011c1.au
Block 360: start 9440753 len 32768 refs 23 e000189b.au
Block 361: start 9473521 len 32768 refs 23 e00012f8.au
Block 362: start 9506289 len 17921 refs 15 e0003dd8.au
Block 363: start 9524210 len 19948 refs 1 e0005350.au
Block 364: start 9544158 len 19948 refs 1 e00059ad.au
Block 365: start 9564106 len 21068 refs 13 e0003d14.au
Block 366: start 9585174 len 32768 refs 26 e0001b1f.au
Block 367: start 9617942 len 32768 refs 26 e0001532.au
Block 368: start 9650710 len 20058 refs 13 e0003689.au
Block 369: start 9670768 len 20059 refs 13 e0003a57.au
Block 370: start 9690827 len 32768 refs 22 e0001103.au
Block 371: start 9723595 len 26209 refs 14 e0003dfd.au
Block 372: start 9749804 len 26209 refs 14 e0003d05.au
Block 373: start 9776013 len 26210 refs 14 e000338c.au
Block 374: start 9802223 len 32768 refs 23 e0001bab.au
Block 375: start 9834991 len 32768 refs 23 e0001f0c.au
Block 376: start 9867759 len 20405 refs 1 e00051cb.au
Block 377: start 9888164 len 19337 refs 1 e0005f33.au
Block 378: start 9907501 len 19337 refs 1 e0005516.au
Block 379: start 9926838 len 23441 refs 9 e000378d.au
Block 380: start 9950279 len 23441 refs 9 e00031b4.au
Block 381: start 9973720 len 20243 refs 9 e0003633.au
Block 382: start 9993963 len 31911 refs 9 e00037ac.au
Block 383: start 10025874 len 27835 refs 9 e0003f6a.au
Block 384: start 10053709 len 22505 refs 11 e0003161.au
Block 385: start 10076214 len 22574 refs 8 e0004f89.au
Block 386: start 10098788 len 22575 refs 8 e0004e7d.au
Block 387: start 10121363 len 31187 refs 8 e000461f.au
Block 388: start 10152550 len 31188 refs 8 e00040dd.au
Block 389: start 10183738 len 21907 refs 9 e00034de.au
Block 390: start 10205645 len 17157 refs 17 e0003289.au
Block 391: start 10222802 len 30036 refs 25 e0002618.au
Block 392: start 10252838 len 30037 refs 25 e0002d76.au
Block 393: start 10282875 len 23082 refs 20 e00021e0.au
Block 394: start 10305957 len 23082 refs 20 e0002d05.au
Block 395: start 10329039 len 23083 refs 20 e0002c62.au
Block 396: start 10352122 len 23579 refs 22 e0002267.au
Block 397: start 10375701 len 18293 refs 15 e0003361.au
Block 398: start 10393994 len 18294 refs 15 e0003fed.au
Block 399: start 10412288 len 32768 refs 24 e00011bb.au
Block 400: start 10445056 len 32768 refs 24 e000163f.au
Block 401: start 10477824 len 30736 refs 22 e0002ddd.au
Block 402: start 10508560 len 31935 refs 5 e0004511.au
Block 403: start 10540495 len 32768 refs 27 e0001e60.au
Block 404: start 10573263 len 32768 refs 27 e00014b2.au
Block 405: start 10606031 len 32768 refs 27 e0001d00.au
Block 406: start 10638799 len 22268 refs 23 e0002c93.au
Block 407: start 10661067 len 22269 refs 23 e000279c.au
Block 408: start 10683336 len 22269 refs 23 e0002b0f.au
Block 409: start 10705605 len 32768 refs 28 e0000bb6.au
Block 410: start 10738373 len 32541 refs 10 e0004f94.au
Block 411: start 10770914 len 32542 refs 10 e0004725.au
Block 412: start 10803456 len 25978 refs 5 e00049ec.au
Block 413: start 10829434 len 16856 refs 18 e0004e61.au
Block 414: start 10846290 len 29002 refs 19 e0003b5f.au
Block 415: start 10875292 len 29868 refs 2 e000529d.au
Block 416: start 10905160 len 29869 refs 2 e0005663.au
Block 417: start 10935029 len 27131 refs 31 e000128e.au
Block 418: start 10962160 len 21238 refs 11 e0004f35.au
Block 419: start 10983398 len 19175 refs 11 e0004abe.au
Block 420: start 11002573 len 23262 refs 26 e00034ef.au
Block 421: start 11025835 len 30227 refs 20 e0003898.au
Block 422: start 11056062 len 22580 refs 31 e0003543.au
Block 423: start 11078642 len 22581 refs 31 e000359a.au
Block 424: start 11101223 len 22645 refs 4 e0005e8e.au
Block 425: start 11123868 len 22646 refs 4 e000522b.au
Block 426: start 11146514 len 22646 refs 4 e0005f4d.au
Block 427: start 11169160 len 24519 refs 20 e0003b3e.au
Block 428: start 11193679 len 24519 refs 20 e0003d48.au
Block 429: start 11218198 len 32768 refs 27 e0001b57.au
Block 430: start 11250966 len 32768 refs 27 e0001486.au
Block 431: start 11283734 len 32768 refs 27 e000116b.au
Block 432: start 11316502 len 32768 refs 27 e0001a9d.au
Block 433: start 11349270 len 26162 refs 18 e00035b1.au
Block 434: start 11375432 len 17745 refs 18 e0003c22.au
Block 435: start 11393177 len 32768 refs 37 e00002f2.au
Block 436: start 11425945 len 32768 refs 37 e0000fe0.au
Block 437: start 11458713 len 32768 refs 37 e000000b.au
Block 438: start 11491481 len 32768 refs 37 e00004db.au
Block 439: start 11524249 len 32768 refs 37 e00007a6.au
Block 440: start 11557017 len 24104 refs 25 e000382c.au
Block 441: start 11581121 len 24105 refs 25 e0003d96.au
Block 442: start 11605226 len 18963 refs 33 e0002268.au
Block 443: start 11624189 len 26218 refs 33 e0002538.au
Block 444: start 11650407 len 32768 refs 37 e000052b.au
Block 445: start 11683175 len 32768 refs 37 e000052f.au
Block 446: start 11715943 len 32768 refs 37 e0000f40.au
Block 447: start 11748711 len 32768 refs 37 e0000e51.au
Block 448: start 11781479 len 32768 refs 37 e0000a20.au
Block 449: start 11814247 len 24066 refs 15 e0003cec.au
Block 450: start 11838313 len 24067 refs 15 e0003d51.au
Block 451: start 11862380 len 24067 refs 15 e0003068.au
Block 452: start 11886447 len 29439 refs 14 e0004d58.au
Block 453: start 11915886 len 29440 refs 14 e000480a.au
Block 454: start 11945326 len 23814 refs 17 e0003daf.au
Block 455: start 11969140 len 25347 refs 19 e00027ed.au
Block 456: start 11994487 len 32768 refs 22 e0001618.au
Block 457: start 12027255 len 18561 refs 21 e0002386.au
Block 458: start 12045816 len 18105 refs 21 e0002d08.au
Block 459: start 12063921 len 16835 refs 14 e0004121.au
Block 460: start 12080756 len 16836 refs 14 e000408f.au
Block 461: start 12097592 len 22161 refs 19 e0003228.au
Block 462: start 12119753 len 23041 refs 23 e0002917.au
Block 463: start 12142794 len 22770 refs 14 e00036d2.au
Block 464: start 12165564 len 22771 refs 14 e0003004.au
Block 465: start 12188335 len 19863 refs 12 e000499b.au
Block 466: start 12208198 len 19864 refs 12 e0004ae2.au
Block 467: start 12228062 len 17222 refs 12 e0004bb2.au
Block 468: start 12245284 len 17223 refs 12 e0004c7c.au
Block 469: start 12262507 len 26042 refs 22 e0002569.au
Block 470: start 12288549 len 26043 refs 22 e000218c.au
Block 471: start 12314592 len 32768 refs 26 e000132c.au
Block 472: start 12347360 len 32768 refs 26 e0001261.au
Block 473: start 12380128 len 32768 refs 26 e0001ef0.au
Block 474: start 12412896 len 32768 refs 26 e0001bc1.au
Block 475: start 12445664 len 32768 refs 26 e0001ed3.au
Block 476: start 12478432 len 32768 refs 26 e00016eb.au
Block 477: start 12511200 len 32768 refs 26 e000100c.au
Block 478: start 12543968 len 18872 refs 18 e00037ca.au
Block 479: start 12562840 len 18873 refs 18 e0003b85.au
Block 480: start 12581713 len 30844 refs 15 e000301b.au
Block 481: start 12612557 len 32768 refs 29 e0000844.au
Block 482: start 12645325 len 32768 refs 29 e000091c.au
Block 483: start 12678093 len 32768 refs 29 e00008c1.au
Block 484: start 12710861 len 32768 refs 29 e000069f.au
Block 485: start 12743629 len 32768 refs 29 e0000bfd.au
Block 486: start 12776397 len 20721 refs 15 e0003000.au
Block 487: start 12797118 len 20721 refs 15 e0003473.au
Block 488: start 12817839 len 24960 refs 15 e00036a5.au
Block 489: start 12842799 len 24960 refs 15 e0003d0f.au
Block 490: start 12867759 len 24960 refs 15 e0003680.au
Block 491: start 12892719 len 32768 refs 16 e000030c.au
Block 492: start 12925487 len 32768 refs 16 e0000f43.au
Block 493: start 12958255 len 27798 refs 15 e0003ea8.au
Block 494: start 12986053 len 24070 refs 15 e00037e9.au
Block 495: start 13010123 len 24070 refs 15 e0003ea5.au
Block 496: start 13034193 len 24336 refs 26 e00018af.au
Block 497: start 13058529 len 24336 refs 26 e00010f1.au
Block 498: start 13082865 len 31122 refs 14 e0003352.au
Block 499: start 13113987 len 31123 refs 14 e0003356.au
Block 500: start 13145110 len 22531 refs 21 e0003658.au
Block 501: start 13167641 len 22093 refs 15 e000312d.au
Block 502: start 13189734 len 23980 refs 11 e0004fc8.au
Block 503: start 13213714 len 18947 refs 11 e0004a2d.au
Block 504: start 13232661 len 18947 refs 11 e0004e5a.au
Block 505: start 13251608 len 32768 refs 29 e0000fcd.au
Block 506: start 13284376 len 28302 refs 6 e00048bd.au
Block 507: start 13312678 len 28303 refs 6 e0004e9c.au
Block 508: start 13340981 len 32768 refs 23 e0000987.au
Block 509: start 13373749 len 32768 refs 23 e000091e.au
Block 510: start 13406517 len 32768 refs 23 e0000328.au
Block 511: start 13439285 len 32768 refs 23 e0000f5a.au
Block 512: start 13472053 len 32768 refs 23 e0000b7e.au
Block 513: start 13504821 len 30358 refs 6 e0004779.au
Block 514: start 13535179 len 30358 refs 6 e0004d05.au
Block 515: start 13565537 len 30359 refs 6 e0004dd8.au
Block 516: start 13595896 len 32768 refs 23 e00008a5.au
Block 517: start 13628664 len 32768 refs 23 e000013b.au
Block 518: start 13661432 len 32768 refs 23 e0000843.au
Block 519: start 13694200 len 32768 refs 23 e00003d0.au
Block 520: start 13726968 len 32768 refs 23 e00001c9.au
Block 521: start 13759736 len 22772 refs 5 e00054b8.au
Block 522: start 13782508 len 22773 refs 5 e000524a.au
Block 523: start 13805281 len 23916 refs 5 e0005907.au
Block 524: start 13829197 len 23916 refs 5 e00057c8.au
Block 525: start 13853113 len 32768 refs 31 e0001b42.au
Block 526: start 13885881 len 32768 refs 31 e000186f.au
Block 527: start 13918649 len 32768 refs 31 e0001cf7.au
Block 528: start 13951417 len 16772 refs 8 e000455a.au
Block 529: start 13968189 len 28024 refs 6 e0004c8f.au
Block 530: start 13996213 len 28025 refs 6 e0004242.au
Block 531: start 14024238 len 30737 refs 23 e0002046.au
Block 532: start 14054975 len 32768 refs 26 e0000767.au
Block 533: start 14087743 len 32768 refs 26 e0000a53.au
Block 534: start 14120511 len 32768 refs 26 e000032d.au
Block 535: start 14153279 len 24069 refs 7 e0004744.au
Block 536: start 14177348 len 24069 refs 7 e00047e7.au
Block 537: start 14201417 len 23176 refs 7 e0004d93.au
Block 538: start 14224593 len 23177 refs 7 e0004f97.au
Block 539: start 14247770 len 25595 refs 25 e0002147.au
Block 540: start 14273365 len 25798 refs 27 e000200f.au
Block 541: start 14299163 len 27593 refs 27 e0002e9e.au
Block 542: start 14326756 len 27593 refs 27 e0002836.au
Block 543: start 14354349 len 32768 refs 29 e00005b7.au
Block 544: start 14387117 len 29062 refs 18 e0003c1a.au
Block 545: start 14416179 len 29063 refs 18 e000333b.au
Block 546: start 14445242 len 32768 refs 26 e00011b3.au
Block 547: start 14478010 len 32768 refs 26 e00013e3.au
Block 548: start 14510778 len 18336 refs 24 e0002ef4.au
Block 549: start 14529114 len 18336 refs 24 e00025ee.au
Block 550: start 14547450 len 23492 refs 9 e0004118.au
Block 551: start 14570942 len 23493 refs 9 e000458c.au
Block 552: start 14594435 len 27093 refs 2 e0005446.au
Block 553: start 14621528 len 27094 refs 2 e0005ab5.au
Block 554: start 14648622 len 26447 refs 11 e00048fd.au
Block 555: start 14675069 len 26447 refs 11 e00043c7.au
Block 556: start 14701516 len 26718 refs 25 e0002e67.au
Block 557: start 14728234 len 22127 refs 15 e00047e5.au
Block 558: start 14750361 len 22128 refs 15 e00045d3.au
Block 559: start 14772489 len 22128 refs 15 e0004e64.au
Block 560: start 14794617 len 32768 refs 33 e0000497.au
Block 561: start 14827385 len 32768 refs 33 e0000ec7.au
Block 562: start 14860153 len 18569 refs 4 e000521f.au
Block 563: start 14878722 len 18414 refs 3 e0005838.au
Block 564: start 14897136 len 18415 refs 3 e0005f05.au
Block 565: start 14915551 len 21326 refs 18 e0002de6.au
Block 566: start 14936877 len 28543 refs 10 e0004262.au
Block 567: start 14965420 len 28543 refs 10 e0004fa8.au
Block 568: start 14993963 len 25148 refs 15 e0002f30.au
Block 569: start 15019111 len 32768 refs 22 e0001de9.au
Block 570: start 15051879 len 32768 refs 22 e0001bba.au
Block 571: start 15084647 len 32768 refs 22 e00010e8.au
Block 572: start 15117415 len 32768 refs 22 e0001a35.au
Block 573: start 15150183 len 32768 refs 22 e0001930.au
Block 574: start 15182951 len 32768 refs 22 e00014fb.au
Block 575: start 15215719 len 22440 refs 10 e00040a5.au
Block 576: start 15238159 len 22441 refs 10 e0004c89.au
Block 577: start 15260600 len 32768 refs 30 e00007fd.au
Block 578: start 15293368 len 32768 refs 30 e0000580.au
Block 579: start 15326136 len 21150 refs 2 e0005e5d.au
Block 580: start 15347286 len 21150 refs 2 e00051d5.au
Block 581: start 15368436 len 20494 refs 2 e00051e2.au
Block 582: start 15388930 len 20494 refs 2 e000543e.au
Block 583: start 15409424 len 32768 refs 26 e0001152.au
Block 584: start 15442192 len 31591 refs 8 e0004eea.au
Block 585: start 15473783 len 31592 refs 8 e0004f11.au
Block 586: start 15505375 len 30948 refs 12 e0004dfc.au
Block 587: start 15536323 len 30948 refs 12 e00042c3.au
Block 588: start 15567271 len 32768 refs 24 e0001ab5.au
Block 589: start 15600039 len 32768 refs 24 e00013a5.au
Block 590: start 15632807 len 20321 refs 4 e0005f4f.au
Block 591: start 15653128 len 20321 refs 4 e0005d1e.au
Block 592: start 15673449 len 27606 refs 19 e0003034.au
Block 593: start 15701055 len 27606 refs 19 e0003c03.au
Block 594: start 15728661 len 32768 refs 40 e0000909.au
Block 595: start 15761429 len 30351 refs 38 e0002335.au
Block 596: start 15791780 len 30351 refs 38 e000216a.au
Block 597: start 15822131 len 28310 refs 16 e0003153.au
Block 598: start 15850441 len 28311 refs 16 e0003e4e.au
Block 599: start 15878752 len 26900 refs 28 e0000f71.au
Block 600: start 15905652 len 29297 refs 24 e0002d37.au
Block 601: start 15934949 len 29298 refs 24 e0002ded.au
Block 602: start 15964247 len 24247 refs 24 e00021a1.au
Block 603: start 15988494 len 32768 refs 30 e0000fdd.au
Block 604: start 16021262 len 32768 refs 30 e0000c60.au
Block 605: start 16054030 len 32768 refs 30 e000026e.au
Block 606: start 16086798 len 26006 refs 30 e0001836.au
Block 607: start 16112804 len 21934 refs 13 e000412c.au
Block 608: start 16134738 len 21934 refs 13 e0004043.au
Block 609: start 16156672 len 30992 refs 9 e000459d.au
Block 610: start 16187664 len 17996 refs 9 e0004197.au
Block 611: start 16205660 len 17997 refs 9 e00043ac.au
Block 612: start 16223657 len 23102 refs 14 e00032f2.au
Block 613: start 16246759 len 17918 refs 20 e00028ea.au
Block 614: start 16264677 len 30218 refs 10 e00049fa.au
Block 615: start 16294895 len 21090 refs 25 e0002a2f.au
Block 616: start 16315985 len 32768 refs 31 e000096c.au
Block 617: start 16348753 len 29477 refs 19 e000392a.au
Block 618: start 16378230 len 29477 refs 19 e000385f.au
Block 619: start 16407707 len 16994 refs 20 e00037c4.au
Block 620: start 16424701 len 16994 refs 20 e0003a21.au
Block 621: start 16441695 len 22686 refs 20 e0003e00.au
Block 622: start 16464381 len 32768 refs 25 e0001f61.au
Block 623: start 16497149 len 21204 refs 1 e0005595.au
Block 624: start 16518353 len 21204 refs 1 e000578e.au
Block 625: start 16539557 len 19582 refs 15 e00032b0.au
Block 626: start 16559139 len 29642 refs 3 e0004d13.au
Block 627: start 16588781 len 22168 refs 3 e0004e37.au
Block 628: start 16610949 len 23050 refs 19 e0003721.au
Block 629: start 16633999 len 23930 refs 1 e00054fe.au
Block 630: start 16657929 len 20843 refs 1 e0005029.au
Block 631: start 16678772 len 24469 refs 6 e0003aac.au
Block 632: start 16703241 len 22352 refs 4 e0003981.au
Block 633: start 16725593 len 22352 refs 4 e0003560.au
Block 634: start 16747945 len 18101 refs 1 e000489c.au
Block 635: start 16766046 len 11134 refs 1 e0004eb8.au
Time to perform 100 edits: 2734 ms
Doing correctness check...
Passed correctness check!
Time to check all data: 3201 ms
Reading data again...
Time to check all data (2): 3071 ms
At 44100 Hz, 16-bits per sample, the estimated number of
simultaneous tracks that could be played at once: 123.9
and from my terminal i get this
[email protected]:~> lsmod
Module Size Used by
nfs 405152 0
lockd 95636 1 nfs
nls_iso8859_1 5672 1
nls_cp437 7368 1
fscache 52048 1 nfs
nfs_acl 4072 1 nfs
vfat 15240 1
auth_rpcgss 56928 1 nfs
fat 68600 1 vfat
sunrpc 267144 5 nfs,lockd,nfs_acl,auth_rpcgss
ip6t_LOG 7980 6
xt_tcpudp 4104 2
xt_pkttype 2248 3
ipt_LOG 7660 6
xt_limit 4076 12
af_packet 28680 4
snd_pcm_oss 60032 0
snd_mixer_oss 22728 1 snd_pcm_oss
snd_seq 78560 3
snd_seq_device 10460 1 snd_seq
edd 13232 0
cpufreq_conservative 10360 0
cpufreq_userspace 4364 0
cpufreq_powersave 2152 0
powernow_k8 19340 0
ip6t_REJECT 6856 3
nf_conntrack_ipv6 26632 4
ip6table_raw 3720 1
xt_NOTRACK 2248 4
ipt_REJECT 4136 3
xt_state 2920 8
iptable_raw 3560 1
iptable_filter 4520 1
ip6table_mangle 5000 0
nf_conntrack_netbios_ns 3400 0
nf_conntrack_ipv4 14232 4
nf_conntrack 101952 5 nf_conntrack_ipv6,xt_NOTRACK,xt_state,nf_conntrack_netbios_ns,nf_conntrack_ipv4
nf_defrag_ipv4 2856 1 nf_conntrack_ipv4
ip_tables 24536 2 iptable_raw,iptable_filter
ip6table_filter 4552 1
ip6_tables 26072 4 ip6t_LOG,ip6table_raw,ip6table_mangle,ip6table_filter
x_tables 30768 11 ip6t_LOG,xt_tcpudp,xt_pkttype,ipt_LOG,xt_limit,ip6t_REJECT,xt_NOTRACK,ipt_REJECT,xt_state,ip_tables,ip6_tables
fuse 87984 5
loop 22292 0
dm_mod 101544 0
arc4 2568 2
ecb 4168 2
cryptomgr 109904 0
aead 10792 1 cryptomgr
pcompress 3560 1 cryptomgr
crypto_blkcipher 18028 2 ecb,cryptomgr
crypto_hash 17416 1 cryptomgr
crypto_algapi 25904 7 arc4,ecb,cryptomgr,aead,pcompress,crypto_blkcipher,crypto_hash
ath9k 279412 0
mac80211 257120 1 ath9k
ath 11048 1 ath9k
snd_hda_codec_realtek 318124 1
snd_hda_intel 37280 5
snd_hda_codec 111112 2 snd_hda_codec_realtek,snd_hda_intel
snd_hwdep 11216 1 snd_hda_codec
snd_pcm 117808 5 snd_pcm_oss,snd_hda_intel,snd_hda_codec
fglrx 2324024 31
snd_timer 32152 2 snd_seq,snd_pcm
cfg80211 123296 3 ath9k,mac80211,ath
sr_mod 20964 0
snd 97608 19 snd_pcm_oss,snd_mixer_oss,snd_seq,snd_seq_device,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_timer
amd64_edac_mod 39392 0
shpchp 43620 0
pcspkr 3720 0
joydev 14400 0
k8temp 6440 0
edac_core 60788 1 amd64_edac_mod
snd_page_alloc 12600 2 snd_hda_intel,snd_pcm
cdrom 48232 1 sr_mod
sg 40128 0
i2c_piix4 16088 0
rfkill 28176 1 cfg80211
atl1c 45868 0
wmi 9600 0
video 29156 0
pci_hotplug 39640 1 shpchp
ac 6416 0
battery 15824 0
button 8360 0
preloadtrace 131248 0
ext4 426040 1
jbd2 115712 1 ext4
crc16 2504 1 ext4
fan 6352 0
processor 56932 1 powernow_k8
thermal 25160 0
thermal_sys 21888 4 video,fan,processor,thermal
then the device list and all devices are monitored for changes.
[email protected]:~> lshal -t
computer
computer_alsa_sequencer
computer_logicaldev_input_3
acpi_CPU0
computer_alsa_timer
net_computer_loopback
computer_backlight
computer_logicaldev_input_2
computer_logicaldev_input_1
computer_power_supply_battery_BAT1
computer_logicaldev_input_0
computer_power_supply_ac_adapter_ACAD
pnp_PNP0c01
pnp_PNP0c02_0
pnp_SYN1b1d
pnp_PNP0303
pnp_PNP0800
pnp_PNP0b00
pnp_PNP0c04
pnp_PNP0200
pnp_PNP0c02
pnp_PNP0a08
platform_vesafb_0
platform_serial8250
platform_regulatory_0
platform_pcspkr
platform_pcspkr_logicaldev_input
platform_i8042
platform_i8042_i8042_AUX_port
platform_i8042_i8042_AUX_port_logicaldev_input
platform_i8042_i8042_KBD_port
platform_i8042_i8042_KBD_port_logicaldev_input
platform_Fixed_MDIO_bus_0
pci_1022_1103
pci_1022_1102
pci_1022_1101
pci_1022_1100
pci_1002_4384
pci_1002_439d
pci_1002_4383
pci_1002_4383_sound_card_0
pci_1002_4383_sound_card_0_oss_pcm_0_0
pci_1002_4383_sound_card_0_oss_mixer__1
pci_1002_4383_sound_card_0_alsa_playback_0
pci_1002_4383_sound_card_0_alsa_capture_0
pci_1002_4383_sound_card_0_alsa_hw_specific_0
pci_1002_4383_sound_card_0_alsa_control__1
pci_1002_4383_logicaldev_input
pci_1002_4385
pci_1002_4396
usb_device_1d6b_2_0000_00_12_2
usb_device_bda_159_20071114173400000
usb_device_bda_159_20071114173400000_if0
usb_device_bda_159_20071114173400000_if0_scsi_host
usb_device_bda_159_20071114173400000_if0_scsi_host_scsi_host
usb_device_bda_159_20071114173400000_if0_scsi_host_scsi_device_lun0
storage_serial_Generic__Multi_Card_20071114173400000_0_0
volume_uuid_5221_116D
usb_device_bda_159_20071114173400000_if0_scsi_host_scsi_device_lun0_scsi_generic
usb_device_1d6b_2_0000_00_12_2_if0
pci_1002_4398
usb_device_1d6b_1_0000_00_12_1
usb_device_1d6b_1_0000_00_12_1_if0
pci_1002_4397
usb_device_1d6b_1_0000_00_12_0
usb_device_1d6b_1_0000_00_12_0_if0
pci_1002_4391
pci_1002_4391_scsi_host_4
pci_1002_4391_scsi_host_3
pci_1002_4391_scsi_host_2
pci_1002_4391_scsi_host_1
pci_1002_4391_scsi_host_0
pci_1002_4391_scsi_host_0_scsi_host
pci_1002_4391_scsi_host_0_scsi_device_lun0
storage_model_DVD_A__DS8A4SH
volume_empty_dvd_r
pci_1002_4391_scsi_host_0_scsi_device_lun0_scsi_generic
pci_1002_4391_scsi_host_scsi_host
pci_1002_4391_scsi_host_scsi_device_lun0
storage_serial_WDC_WD1600BEVT_22ZCT0_WD_WXJ0A99M7728
volume_part2_size_1024
volume_uuid_1a4a8ae1_a4a9_457d_8d1e_3804eca2be74
volume_uuid_5559d7e9_093f_4e57_9a61_2c7ffa7351b8
pci_1002_4391_scsi_host_scsi_device_lun0_scsi_generic
pci_1022_9605
pci_1969_1062
net_00_26_22_81_06_c2
pci_1022_9604
pci_168c_2a
net_90_4c_e5_1c_9b_c9_0
leds_ath9k_phy0_tx
leds_ath9k_phy0_rx
leds_ath9k_phy0_radio
leds_ath9k_phy0_assoc
pci_168c_2a_rfkill_phy0_wlan
pci_1022_9602
pci_1002_9612
pci_1022_9600
so what any of this means i wish i knew i really would like to be back to making beats so any help please and of course thanks
Re: suse help wont record or hangs/ intermitant playback
Post by steve » Tue Apr 27, 2010 3:57 pm
It appears that you have Jack running.
In Audacity Edit menu > Preferences > Devices, select "Host: Jack"
Playback and recording devices should then automatically be set to "System".
subliminalfix
Post by subliminalfix » Tue Apr 27, 2010 4:51 pm
thanks for your reply i had uploaded this (jack) while trying to get things going
i am unsure of using this as a patch if it is a problem with other o.s.u/linux distro
and actually my experience in the past with ubuntu studio i had to remove jack because of the conflict with alsa bridge
so i was hesitant to even try it here.
im not sure what your running but if you can wade through the package adding in yast suse
http://forums.opensuse.org/information- ... guide.html
(helps to add alot of other lib-'libraries" as well using this guide)
will give you alot more robust g.u.i. and has quite a bit of advanced graphical design "effects" in comparison to
the newer ubuntu. (doesnt drop wireless signal and can use a left handed mouse as well)
anyway long story short i seem to be up and running for now
the only gripe i have that i didnt experience with the w7 or xp is i cannot play through until i actually start recording
although i have supple disk space it creates more work as i sometimes wait to start recording until i have ogmented several parts of the oscilation in my mix
once again thanks for the response and thank God im finally able to use this after about 10 days of seaching the net and tweaking my seed :D
bgravato
Post by bgravato » Wed Apr 28, 2010 1:46 am
jack can be a bit tricky to get it to work flawlessy, but once you get it working it should work pretty good! I'd advise to go for jack2 (which is actually 1.x versions, if you have 0.xxx version then it's jack1, which sometimes can give some quirks...).
Anyway I'm glad you managed to make it work :)
If you have any more troubles just ask!
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
