I'm having a problem recording streaming audio. Audacity can record when I inject audio into my mic input, but cannot directly record audio streamed to my computer.
Here is some info:
Audacity 1.3.2-beta is loaded into Fedora 8.
Enable software sound mixing (ESD) is off.
Audacity Device toolbar shows: Speaker--greyed out. Mic--ALSA: HDA Intel: STAC92xx Analog (hw:0,0)
Mixer toolbar shows a Speaker icon and a Mic icon both with slider bars. To the right of that, a pulldown menu with the choices: Capture:0,1,2 and Mux:0,1,2
About Audacity shows:
MP3 importing disabled
Off Vorbis importing enabled
ID3 tag exporting enabled
FLAD plug-in support enabled
LADSPA plug-in support enabled
Libsamplerate support enabled
PortAudio v19
wsWidgets 2.6.3
Any help would be appreciated. Audacity is important to me.
Recording Internet Radio
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
waxcylinder
Re: Recording Internet Radio
