No mic input in Debian Squeeze KDE
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Zelator
Post by Zelator » Mon Mar 08, 2010 8:37 am
The mic works, Audacity plays, but does not record. I tried the solution given in an earlier post "no mic audacity only Ubuntu 9.10" in case it applied, but the PulseAudio Volume Control does not recognise that Audacity is recording, so the "Recording" tab remains blank. Audacity will not start if the PulseAudio Volume Control is up, so I have to start Audacity first.
I have Audacity running fine in Lenny, where it uses OSS, but in Squeeze if I try OSS Audacity tells me to check the device settings and sample rate.
Re: No mic input in Debian Squeeze KDE
Post by steve » Mon Mar 08, 2010 10:20 pm
Do you have a fully functional PulseAudio/ALSA set-up?
Which version of Audacity are you using? (recommended version 1.3.11 or 1.3.12)
