Audacity freezing while recording more than one track.
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
eitany
Re: Audacity freezing while recording more than one track.
Post by eitany » Fri May 14, 2010 5:40 pm
stinni3 wrote:Im using Audacity 1.3.9 (Unicode) and Im having trouble while recording. I am using MobilePre USB interface. Recording the first track works fine but when I start recording the second or third track it records for one or two second and freezes than. I have unchecked the Software playthrough button but it still doesnt work. I found out that if I uncheck the Overdub button also i can record as many tracks as I want to. But how am I supposed to be able to record while I cant hear the other tracks?
I had the same problem with overdubbing with my usb mic, on the same os (ubuntu 9.10). I think it had to do with the system default recording device. I managed to solve it by:
- going into the linux gui system-sound menu, and there:
- setting the usb mic to be default
- switching to mono
- setting in audacity in the preferences-devices the 'recording' and 'playback' fields to 'default'
- switching to mono recording in audacity
After that recording with overdubbing started to work fine.
