Can't download help file
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Garthhh
Post by Garthhh » Tue Dec 01, 2009 12:05 am
Unbuntu 8.04
new install, from scratch
I need the help file as this version is different enough from the 3 year old version I was running so as to be confusing
85% of All Statistics Are Completely Made Up
Re: Can't download help file
Post by steve » Tue Dec 01, 2009 12:20 am
The easiest way to access the manual is on-line: http://manual.audacityteam.org/index.ph ... =Main_Page
(also instructions for how too download it on the same page)
Garthhh
Post by Garthhh » Tue Dec 01, 2009 12:57 am
Thanks for the help
I don't quite follow how to save it in the right place?
Post by steve » Tue Dec 01, 2009 2:09 am
1) When you extract the zip file it should produce a folder called "help" with a load of files in it. (if it just creates a load of files, then you need to put them in a folder and name the folder "help" (without quotes).
2) If you have a folder /usr/share/audacity/ then the "help" folder (from step 1 above) needs to go into that audacity folder. If the /audacity/ folder is somewhere else (for example /usr/local/share/audacity/ ) then you need to put the help folder in there.
