Hallo
I use audacity 1.3.7 om ubuntu 9.04. When i import a MP3 file the first notes are pushed aside.
It seems the number don't start at the biginning.
Is there a way to change this??
fixer
when importing MP3 it skips the thirst notes.
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
- Quality Assurance
Re: when importing MP3 it skips the thirst notes.
MP3s always have silence padding. What application encoded the MP3 that you are importing?fixer wrote:Hallo
Do you mean the notes are visible in the waveform of the MP3 but not played? If you have moved the track away from time zero, try selecting it and Tracks > Resample to the current project rate.
Is your system version of LIBMAD (for MP3 decoding) up-to-date?
