Compillation error (Fixed)
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
tadi70
Post by tadi70 » Sat Jul 25, 2009 10:21 am
Hello there,
Trying to compile Audacity 1.3.8 on Slackware with gcc 4.3.3:
make[3]: Entering directory `/tmp/slackpack/audacity-1.3.8/audacity-1.3.8/lib-src/twolame/libtwolame'
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../build -I ../build/ -O2 -march=i686 -mtune=i686 -std=c99 -Wunused -Wall -g -Werror -pedantic -MT crc.lo -MD -MP -MF .deps/crc.Tpo -c -o crc.lo crc.c
gcc -DHAVE_CONFIG_H -I. -I../build -I ../build/ -O2 -march=i686 -mtune=i686 -std=c99 -Wunused -Wall -g -Werror -pedantic -MT crc.lo -MD -MP -MF .deps/crc.Tpo -c crc.c -fPIC -DPIC -o .libs/crc.o
cc1: warnings being treated as errors
bitbuffer.h:47: error: inline function 'buffer_sstell' declared but never defined
bitbuffer.h:46: error: inline function 'buffer_putbits' declared but never defined
bitbuffer.h:45: error: inline function 'buffer_put1bit' declared but never defined
make[3]: *** [crc.lo] Error 1
make[3]: Leaving directory `/tmp/slackpack/audacity-1.3.8/audacity-1.3.8/lib-src/twolame/libtwolame'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/tmp/slackpack/audacity-1.3.8/audacity-1.3.8/lib-src/twolame'
make[1]: *** [libtwolame-recursive] Error 2
make[1]: Leaving directory `/tmp/slackpack/audacity-1.3.8/audacity-1.3.8/lib-src'
make: *** [audacity] Error 2
Any idea?
Thanks,
tadi
tadi70
Re: Compillation error
Post by tadi70 » Sat Jul 25, 2009 11:24 am
Fixed!!!
After some time spent I managed to fix that compilation error. Here is the patch I did:
--- lib-src/twolame/libtwolame/common.h 2009-07-16 06:27:35.000000000 +0300
+++ lib-src/twolame/libtwolame/common.h 2009-07-25 13:52:57.412328582 +0300
@@ -41,7 +41,7 @@
* extern inline. This fix appears earlier in Apple GCC than in main-line GCC
#if (__GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ >= 3))
-#define NO_DLL_INLINE extern inline
+#define NO_DLL_INLINE extern
#elif (__APPLE_CC__ >= 5465)
# else
