VSTs in Audacity
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
bassix
VSTs in Audacity
Post by bassix » Fri Jul 03, 2009 3:56 am
Hi,
Is there any way to use VSTs in Audacity in linux (Ubuntu)?
Thanks for any suggestions!
Re: VSTs in Audacity
Post by steve » Fri Jul 03, 2009 9:59 am
VST support in Linux is quite limited. The best VST support that you are going to get in Linux is either using Ardour, or running Reaper in WINE. For Linux there are other plug-in architectures supported such as LADSPA, Nyquist and LV2. For awesome plug-in flexibility look at using Ardour with Jack Rack.
