No need for such extreme measures. Audacity 1.3.10 works really well on Jaunty (and Audacity 1.3.9 is not too bad either). If you know how to compile a program from the source code I would recommend installing the current cvs version. If you're not happy with that it may be worth seeing if the Ubuntu Karmic version will run on Jaunty http://packages.ubunut.com/fi/karmic/audacity-dataencore wrote: Experiences like this has been so far, are bad enough to make me reconsider Windowz.
Opening project hangs Audacity 1.3.7
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
Re: Opening project hangs Audacity 1.3.7
