I have recently bought an akai att05U turntable.
i tried to plug in the table in my macbook pro, but at first there was no possibility to see th codec.
Yesterday there was all of a sudden the usb audio codec demo.
This meant a beep every 25 seconds.
When i restarted the audio codec was gone again and i cannot find it anywhrere on the system.
Audacity 1.3.7.
thanks for your advice
usb audio codec osx 1.5.6
Re: usb audio codec osx 1.5.6
by changing usb port i got the demo version back.
does anybody know how to find the real mackoy and what that might be
thanks for the advice
rob bijpost
rob bijpost
waxcylinder
Changing the USB port can often help - sounds like you may have a dodgy USB port - at least you have one that works. Sometimes though it's jus a poor connection, wiggling (gently) the USB plug in its socket or just withdrawing it an re-plugging it can sometimes help. And generally it is not advised to plug them into USB hubs.
