Yes, I have read the instructions and did as much as I could follow. I clicked to download, it downloaded the Labe Lim installer package [the .pkg file] I double clicked to install. It asks me where to install so I made a folder on my desktop and installed it into that folder. When I go to 'Export as MP3', I locate it, but the file [libmp3lame.dylib] is faded out and I can't select it.
Any ideas? IT's probably a simple problem for you guys. I'm on a Mac Intel OS X
Having trouble locating/selecting LabeLim
Re: Having trouble locating/selecting LabeLim
<<<Mac Intel OS X>>>
Almost enough. OS-X...what? Tiger? Leopard? 10.5?
Question Format
http://www.kozco.com/tech/audacity/question.html
Have you ever done a Verify Disk and Repair Permissions on your machine?
Question Format
