App not responding when opening small file
I am opening a small file (actually an Apple sample sound) which causes Audicity to freeze. I am using 1.3.7 beta. I compressed the sample file and attached it.
- Attachments
- Tink.aiff.zip
- (1.97 KiB) Downloaded 64 times
Re: App not responding when opening small file
It plays very nicely by itself on an Intel/Tiger machine. Open it up in QuickTime and Apple-I Info the audio standards.
How are you playing it? I'm guessing in combination with a bunch of other stuff, right? This clip is 22500 which probably isn't going to match everything else you're doing. If you have a damaged clip somewhere else, that could be actually be causing the problem.
Works fine on Linux too.
For your information:
Format : AIFF
Format/Info : Apple/SGI
File size : 5.87 KiB
Duration : 22ms
Overall bit rate : 2 185 Kbps
Audio
Format : PCM
Duration : 22ms
Bit rate mode : Constant
Bit rate : 705.6 Kbps
Channel(s) : 2 channels
Sampling rate : 22.05 KHz
Resolution : 16 bits
Stream size : 1.88 KiB (32%)
