No sound in saved mp3 file
zrohit
Post by zrohit » Fri Apr 10, 2009 3:14 pm
I am using Audacity version 1.3.3. on a Intel Mac with the latest OS Version.
I am trying to convert an old tape to mp3. I see the audio on Audacity but when I saved it in MP3 there is NO sound in the file. I have tried multiple time but no luck.
Any ideas what could be wrong?
thanks Rohit
Re: No sound in saved mp3 file
Post by kozikowski » Fri Apr 10, 2009 5:11 pm
It's important in Audacity to get the words right. Audacity will not save sound files. You have to Export to get a stand-alone sound file.
Do you get a working sound file if you Export As WAV?
