32-bit float to 24-bit FLAC?
allencmcbride
Re: 32-bit float to 24-bit FLAC?
Post by allencmcbride » Fri Apr 10, 2009 2:17 am
Thanks again. I still plan to do processing in 32 bits. I guess I should try to keep archives in 24 bits in case I decide to process them further. --Allen
Post by kozikowski » Fri Apr 10, 2009 4:36 am
Original Capture Masters or Edit Masters should be in the highest quality you can store. You can always go downhill.
