I have downloaded Audacity 1.3.7. on my iMac to try this version.
However if I choose to export a file, I see the metadata editor window?
I also see this window when I choose multiple export.
I have the dutch version by the way.
So it is not possible to export to wav.
Is this a bug?
Marcel
exporting in wav audacity 1.3.7 not possible bug?
Re: exporting in wav audacity 1.3.7 not possible bug?
By default the Metadata editor comes up before the Export dialogue. Just click on "OK" to move to the next screen.
If you usually export in WAV format, you can change Audacity's preferences so that the Metadata editor does not pop up automatically (Edit > Preferences > Import/Export)
Thanks!
You have solved all my problems with this message.
Marcel
Marcel
