What do you use "Move Cursor to Selection Start/End" for?
soundsun
Post by soundsun » Thu Mar 19, 2009 9:35 pm
What's the purpose of the commands Edit-->Move Cursor-->to Selection Start/End? I thought that it would be to fine-tune a selection I've made, but when I execute either one, while it does move the cursor to the start or end of the selection it also looses the selection.
Thanks,
--Phil
Audacity 1.3.7 & Mac 10.5.6
Re: What do you use "Move Cursor to Selection Start/End" for
Post by Gale Andrews » Mon Mar 23, 2009 2:49 am
soundsun wrote:What's the purpose of the commands Edit-->Move Cursor-->to Selection Start/End? I thought that it would be to fine-tune a selection I've made, but when I execute either one, while it does move the cursor to the start or end of the selection it also looses the selection.
That's exactly what it does do, because you can't have the cursor inside a selection in Audacity, there is either a selection region or a cursor point. To fine tune the selection boundaries with the keyboard, you can use [ and ], or SHIFT - left or right arrow to expand the selection, or COMMAND - SHIFT - left or right arrow to contract it.
You can also label the selection (COMMAND - B) then click in the label to recall the selection.
