I've got a 'Edirol UA-26EX Audio Interface' and connected to it is 2 Studio Monitors, i have the tec-3100 connected by usb into my iMac. i have audacity installed on it and I've gone to record and I've got this error message "Error while opening sound device. Please check the device input settings and the project sample rate."
I have already gone to in system preferences and set i to the 'Audio Codec USB ' which i know is the turntable because the volume bar bouces up and down while it plays. i have also got my edirol audio interface set up as the output.
i have done the same settings in audacity [play back for the edirol and recording for the audio codec] i have also changed the sample rate to the normal settings but i remember seeing my sample rate as 96000 in a music production piece of software called Reason 4.0,and so i tried changing it to that and still no success.
Any Tips and Advice?
Bossman Static
