File/Edit Chains limitation
aadli
Post by aadli » Sun Mar 01, 2009 9:54 pm
Hello.
Is it possible to create a batch process with the Export Multiple command? This possibility does not seem to be included in the commands that are available in the Edit Chains window. Is there otherwise a way to solve this problem by scripting (Mac OS X Leopard)?
Thank you.
Aria
Re: File/Edit Chains limitation
Post by steve » Mon Mar 02, 2009 9:22 pm
Not all functions are supported by chains. Those functions that are not listed are not (yet) supported.
