Export drops last sample
Re: Export drops last sample
Post by Gale Andrews » Thu Apr 09, 2009 4:02 pm
2eleven wrote:Thanks for the analysis Gale. Where would be the right place to track this issue if I want to keep tabs on it?
We've committed a code change that should fix this, you can test it by running this development build.
If you want to, you could get an account on the Wiki and then look at the P3 bugs on the Release Checklist. If you register an e-mail address in Preferences and click the "Watch" tab top of the Checklist, you will be e-mailed every time the Checklist changes. If the fix works then the bug will be removed and this will be noted in the e-mail summary of changes to the Checklist.
2eleven
Post by 2eleven » Thu Apr 09, 2009 4:57 pm
Great to hear this was addressed so quickly. Was it determined if this affects other lengths besides multiples of 22,752,072 samples? It seems like it would be pretty unlikely (about 1 in 22 million) that I would happen to find the only length with this issue, but someone has to win the lottery I guess. Thanks and kudos for the quick turnaround on this one folks.
Cheers,
John
