Need test files for that cause Audacity to hang
Re: Need test files for that cause Audacity to hang
I think it is definitely a 16 bit file because if I create a 1.0 second stereo WAV file at 48kHz (48000 samples), it is 192004 bytes (the same as your file). (2 bytes per sample x 2 channels x 48000 samples. )
Hey Koz.kozikowski wrote: Some of the time it arrives with correct focus, halo, and SpaceBar Play.
The latest nightly should have this fixed.
Leland
20090207 2232 hrs-Pacific
Mac Mini 1.83 GHz Intel Core Duo, 2G memory
Mac OS-X 10.5.6
piano2.wav 16-bit Integer (Little Endian), Stereo, 48.000 KHz.
http://www.kozco.com/tech/soundtests.html
Audacity ® 1.3.8-alpha_Feb 8 2009 (Unicode)
All these conditions produced a good Focus, Golden Halo, and SpaceBar Play.
File > Open...
File > Open Recent >
Right Click Music > Open With...
Drag Music to Audacity Icon in the dock.
While the music is already open, File > Open > piano2.wav and a second work window opens up with Focus, Halo, and SpaceBar Play.
This release did all those things multiple times. It never missed.
Mac OS-X 10.5.6
File > Open...
WOOHOO!!! Finally, eh?kozikowski wrote: This release did all those things multiple times. It never missed.
Thanks for checking all of 'em.
Leland
Also, unsaid, is the Quit functions are working now, too. 1.3.7 had that thing where you had to Quit the program in a wacky way.
Now we just need to get rid of all the exploding outlines and the presentation is pretty much licked. Did you know there are three exploding outlines just to open the program? The open, the opening announcement, and the announcement closing. If you're experimenting with different equalizations for your show, the screen is a festival of exploding outlines.
Gone. All of them.
Gone. All of them.
