Hello, team!
I just got my PreSonus Inspire 1394 FireWire audio interface.
I set it up, and it records fine with Cubase, and GarageBand. But I far prefer Audacity, and that's what I have always used when I had a Windows computer.
When I set it up like all of the others, inputs and outputs configured correctly, and the sample rates set, I click record and it gives me this message:
"Error while opening the sound device. Please check the input device settings and the project sample rate"
They all match up. What do I do?
I downloaded the stable version, and it does the same thing.
Problem recording with PreSonus Inspire 1394
vinyldavid
vinyldavid
Re: Problem recording with PreSonus Inspire 1394
Here are some picx of the problem:
The Error Message:
My Audacity Settings:
The OSX settings:
The Error Message:
The OSX settings:
vinyldavid
I have also tried this with Audacity set for 4 channel recording.
