Hi I'm trying to use a Canopus ADVC110 with my iMac (OSX 10.6) for audio only input into Audacity.
I have the Digidesign Core Audio Driver showing as the Audio Host, but no Canopus box in the drop down "Input' list.
I set up the Canopus box for audio only (Dip 1 to "On"), but still nothing in Audacity.
I see the ADVC110 in iMovie as a video input device, so I know the Firewire is working correctly.
Do i need to disable the Digidesign Core Audi Driver?...any other suggestions?
Thanks,
Cam
First time user, can't see Canopus box in Devices
Re: First time user, can't see Canopus box in Devices
The Canopus delivers a video package, not audio. You might try capturing the show in QuickTime Pro (if they still do it that way) and then save the video file and open the file in Audacity. I think you could also use QuickTime to Export the audio separate from the video. A lot of this changed with QuickTime 10. You're mileage may vary, consult your local listings.
Make sure the Canopus "locked sound" feature is defeated since you won't have a video channel to lock to. Also you might need to add the FFMpeg software to Audacity to open the file.
Or you could get a simple Behringer UCA-202, or UFO-202 if you're trying to digitize a turntable.
http://kozco.com/tech/audacity/pix/UCA202.jpg
http://www.behringer.com/EN/Products/UFO202.aspx
Thanks for your reply, but the Canopus box is supposed to have an "Audi Only" capability. Perhaps that means capturing only audio in a video format?
I thought there was an easy way to capture audio through Audacity with the Canopus box?
Cam
Cam
Audacity only looks for "audio devices" to capture audio data.
If your computer "sees" the Canopus box as a Video capture device, then Audacity will not see it at all.
If you're able to make your computer "see" the Canopus box as an "Audio device", then you should be able to use it with Audacity (I don't know much about Macs but this may not be possible).
As Koz suggested, a workaround would be to use a video capture program to record. If you have FFmpeg installed Audacity can import the audio from several video file formats (though it does not allow you to capture from a video "device").
billw58
Can you see the canopus in System Preferences > Sound > Input?
- Bill
- Bill
I have a 100, so that may have changed. Kozthe Canopus box is supposed to have an "Audi Only" capability.
