using the yeti mic with audacity
tmzawtun
Post by tmzawtun » Sat Feb 11, 2012 10:20 pm
I am using audacity to record simple podcasts and I am also using a yeti microphone. The microphone shows up in system preferences and I have selected it as the input device; however, it does not show up in audacity - not in the drop down selection nor in the preferences. This microphone works on a friend's mac book - they have an older version of audacity and it shows up in audacity. It shows up in my garage band just not audacity. What could be the problem?
Re: using the yeti mic with audacity
Post by Gale Andrews » Sat Feb 11, 2012 11:56 pm
Restart Audacity if you connected the Yeti after launching Audacity.
Otherwise, try setting the mic up in Apple Audio MIDI Setup:
http://wiki.audacityteam.org/wiki/User: ... Midi_Setup .
