How to sync M-audio Interface with Audacity
wrightway
Post by wrightway » Fri Feb 03, 2012 11:20 pm
I have a M-audio NRV10 that i want to sync with audacity.. so how do i find devices
Re: How to sync M-audio Interface with Audacity
Post by kozikowski » Fri Feb 03, 2012 11:56 pm
Close Audacity.
Plug the device in.
Apple (upper left) > Preferences > Hardware > Sound > Input. Select the device. It may not say NRV10. It may say something else, but it won't look like all your regular devices. Play something and your little blue ball sound meter should bounce.
Launch Audacity 1.3. Select the device in the tool bar for Input.
http://manual.audacityteam.org/man/Device_Toolbar
Play something and press record.
The blue waves should start building themselves and the red recording meters should bounce like this.
http://kozco.com/tech/audacity/Audacity1_record.jpg
If you need to hear what you're doing from the Mac, Audacity > Preferences > Recording > Software Playthrough.
wrightway
Post by wrightway » Wed Feb 08, 2012 3:58 am
Thanks Alot!
