I've moved over from ProTools and am still clueless where Audacity is concerned.
Editing audio, and I inadvertently hit something that changed the view of the track I'm on. The sound waves are very tall,
and I'm only seeing the bottoms of them. Like being a kid in a crowd and only seeing everyone's legs.
There's no Undo for this, and I've played around with View and found nothing. I pulled down the arrow menu from the left side of the track in question, and nothing there seems to fit the bill either - the settings are exactly the same for the track above it, which appears normal.
Zooming In, Out, then Normal doesn't solve it.
Whatever I did, I did with the inadvertent touch of one key.
Any ideas? Thanks so much!
Please help, submission deadline!
Re: Please help, submission deadline!
Yeah that happened to me, too. If you hover over the left edge of the waveforms, your cursor will change into a + magnifier. Press/hold Shift and it will change into a - and reduce the vertical size of the waves. Stop when you get to 1 up and 1 down.
Thanks so very much. Saving this in case it happens again.
What I resorted to - and it worked! - was saving the file, shutting down Audacity, and reopening it. Pshew. Project resumed.
Very grateful - thanks!
