Please Help
Taffypro
Please Help
Post by Taffypro » Mon Dec 19, 2011 4:23 pm
Hi,
I am trying to convert .mp3 to .wma on a Mac using Audacity. (Macbookpro running OSX 10.6.8). I've gone to the Preferences/Libraries trying to find the "libacodec.52.dylib" file. I am able to find this file in the User/library/application support/audacity/libavcodec folder. I am able to select it and hit open, but it does nothing after this..
I go back the the Preferences/Library and it still asks me to locate this folder. When I try to export my .mp3 as a .wma I get the following error "Properly configured FFmpeg is required to proceed. You can configure it at Preferences>Libraries.
Any help would be great!
Gary
Moderator note: email removed to prevent spam trawling
Re: Please Help
Post by kozikowski » Mon Dec 19, 2011 6:38 pm
Audacity 1.2 is not supported under Mac-OS-X 10.6. Under certain conditions, it won't even launch.
Download and install Audacity 1.3 from here and get the FFMpeg from the same place.
FFMpeg should come with its own installer. Double click on the package and it should install itself.
Re: Please Help
Post by steve » Mon Dec 19, 2011 6:53 pm
This is the Audacity 1.2 part of the forum.
Audacity 1.2 does not support FFMpeg.
Taffypro
Re: Please Help
Post by Taffypro » Tue Dec 20, 2011 2:34 pm
I am running 1.3.14... I guess Audacity doesn't work? D'oh!
Gary
Re: Please Help
Post by steve » Tue Dec 20, 2011 4:11 pm
Topic moved to the Audacity 1.3.x part of the forum.
Have you seen the instructions here: http://manual.audacityteam.org/index.ph ... tallffmpeg
Please describe exactly what you have done so far and hopefully someone will be able to spot where it's going wrong.
Yes Audacity does work and is used by millions of people worldwide, When things don't go right for people, there are folk here on the forum to try and help.
