Inconvenient window positioning on startup
DevEd
Post by DevEd » Wed Dec 07, 2011 12:57 pm
Whenever I go to startup Audacity, the window spawns in such a position that the title bar is behind the menu bar! What's going on and is there any way I can fix this?
BTW This is a school computer, so I can't do anything that requires root.
billw58
Re: Inconvenient window positioning on startup
Post by billw58 » Wed Dec 07, 2011 3:36 pm
Exactly which version of Audacity are you running? Choose Audacity > About Audacity and tell us the 3-part version number. This issue was resolved a couple of versions ago.
-- Bill
DevEd
Post by DevEd » Thu Dec 08, 2011 12:38 pm
I am using Audacity 1.3.13-beta, Unicode version.
billw58
Post by billw58 » Thu Dec 08, 2011 3:36 pm
Can you open the <home>/Library folder? If so, go to <home>/Library/Application Support/audacity. Trash the "audacity.cfg" file (this is the old "delete the preferences file when all else fails" trick). Then open Audacity. The window should open in the default location.
-- Bill
DevEd
Post by DevEd » Thu Dec 08, 2011 4:04 pm
It worked! Thanks :)
BTW I did this through Terminal.
Edgar
Forum Crew
Post by Edgar » Thu Dec 08, 2011 10:24 pm
DevEd wrote:Whenever I go to startup Audacity, the window spawns in such a position that the title bar is behind the menu bar!
billw58 wrote:Can you ... Trash the "audacity.cfg" file
DevEd wrote:It worked!
I am the programmer who last worked on that code and I thought it was all working just fine. Since I have now seen more than one report of this in the last few weeks I know something is going astray. I sure would like to see a copy of the "audacity.cfg" file which was causing the problem.
I do have a repair for the problem which has been posted by the Audacity Team for testing but as the problem is so rare and transitory it has not been tested yet. PM me or post here and I will point you to the DMG.
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
Post by Gale Andrews » Fri Dec 09, 2011 12:51 am
DevEd wrote:It worked! Thanks :)
Can you find out which version of OS X is being used:
http://www.apple.com/support/mobileme/e ... rsion.html ?
The other recent report we had of this was on OS X 10.7.2. It could be Apple changed something that affects this.
DevEd
Post by DevEd » Tue Dec 13, 2011 2:18 pm
I am using Mac OS X 10.5.8.
BTW I knew how to do that already.
