Only Exporting Single Song
the Muji Fuji
Newbie user - Exporting multiple is only exporting the 1st labled song - what have i missed? Exporting to AIFF - the 1st track exports fine!! Thanks in advance...
Re: Only Exporting Single Song
You should stop using Audacity 1.2 immediately. It can create problems on newer Macs.
http://www.kozco.com/tech/audacity/update.txt
the Muji Fuji
Using v. 1.3.13
billw58
Please have a look at this manual page: http://manual.audacityteam.org/man/Export_Multiple
Do you have more than one label track? How are your labels arranged? Does you project look significantly different from the examples on that page?
-- Bill
-- Bill
the Muji Fuji
OK - I do have a label track for each song...but when I copied them all onto a single label track I got the same result - 1 song exported! Is there any difference if I'm using a region label vs a point label for export-multiple? Perhaps I should start anew with the labeling....
billw58
Please post a screen shot of your project so we can see what you are doing wrong.
-- Bill
-- Bill
