1.3.13 wont download files
hannah.gafter
i cannot download/import files from audacity that i record onto my computer in any form. i have a new macbookAir and i just want to be able to audio and turn it into MPS files. help or ideas?
- Quality Assurance
Re: 1.3.13 wont download files
Please note you posted to the 1.2 Mac Forum, but since you mention 1.3.13 I have moved this to the Beta Mac forum.
If you are trying to record audio that is playing on the computer, see:
http://manual.audacityteam.org/man/Tuto ... ack_on_Mac
If you are actually using Audacity 1.2, please use 1.3.13 instead (assuming you are on OS X 10.4 or higher). You can check your Audacity version at Audacity > About Audacity.
If you still can't import the files into 1.3.13, select an example file in iTunes then right-click or CTRL-click > GetInfo and attach an image of the window that comes up (or tell us everything it says). "Upload attachment" is underneath the message "Preview/Submit" buttons.
If you mean you want to export MP3 files from Audacity, you need to add the optional LAME MP3 encoder to your computer. Here are the instructions:
http://manual.audacityteam.org/man/FAQ: ... ns#maclame
Audacity can't download files from the internet, only import them. If the files you want to import are AAC files they should import if they are not old rights-restricted M4P files from iTunes store. For importing other formats you may need to install FFmpeg.hannah.gafter wrote:i cannot download/import files from audacity that i record onto my computer in any form. i have a new macbookAir and i just want to be able to audio and turn it into MPS files. help or ideas?
