Selecting non-standard project rate
Post by Gale Andrews » Thu Jun 30, 2011 5:11 pm
A user told me on OS X 10.5.8 PPC that if you type a rate not in the list, for example 50000 Hz, then click the arrow that exposes the list of preset rates, the rate you typed is removed from the box so you have to type it again. Can anyone confirm that? Doesn't happen on Windows or Linux, but in any case the answer is to click in the box, not on the arrow.
Re: Selecting non-standard project rate
Post by steve » Thu Jun 30, 2011 5:27 pm
Doesn't happen on by Ubuntu box (unless you click the arrow and select one of the presets).
billw58
Post by billw58 » Fri Jul 01, 2011 2:41 pm
I'm not seeing this with 1.3.14-July 01 nor with 1.3.13-beta on Mac PPC 10.5.8. As long as you drag off the drop-down menu of sample rates so none is selected, then let go, what you typed into the box is not changed.
-- Bill
Post by Gale Andrews » Sat Jul 02, 2011 2:08 am
Many thanks, Bill. I'll point user here and see if he has any more input.
