Transferring portions between tracks
Frungi
Post by Frungi » Sun Jun 12, 2011 7:23 am
Is there any way to do something like select a small section of a stereo track and replace the right channel with the left in that section? The simplest way I can see to do this is to copy the section in the left track, note the selection start/end times, manually enter those times to select the same section of the right track, Generate > Silence, and paste. Surely I’m missing something simpler…
billw58
Re: Transferring portions between tracks
Post by billw58 » Sun Jun 12, 2011 1:25 pm
I assume you have split the stereo track into two tracks. http://manual.audacityteam.org/man/Track_Drop-Down_Menu - Split Stereo Track
Drag the selection across both tracks - fine tune if necessary
Edit > Clip Boundaries > Split
Double-click in the left-channel clip to select it
Edit > Copy
Double-click in the right channel clip to select it
Edit > Paste
Steve wrote a Nyquist plug-in to do this task: http://forum.audacityteam.org/viewtopic ... 44&t=53929
-- Bill
Frungi
Post by Frungi » Sun Jun 12, 2011 2:59 pm
Thanks, this splitting method is much better. Haven’t tried the plugin yet, but I’m surprised it (or something like it) isn’t included by default.
Post by steve » Sun Jun 12, 2011 6:54 pm
Frungi wrote:but I’m surprised it (or something like it) isn’t included by default.
Some of the developers are of the opinion that Effect menu is already too long and are reluctant to add more effects.
There are a lot of additional effects available on the Audacity wiki, and you can find the latest version of the "Channel Repair" plug-in there: http://wiki.audacityteam.org/wiki/Nyqui ... ir_Channel
