As a music teacher, I would like to send AUP files to students and have them record themselves singing their part. Will I have issues with students who open the file on a PC if created on a Mac?
Further, when they save their file and send it back, is there anything specific I should include in the instructions to make the process as streamlined for the students?
Thanks in advance.
sharing files between mac and pc platforms
billw58
Re: sharing files between mac and pc platforms
I assume you mean AUP files (.aup). You can't just send the AUP file - you must also include the _data folder that goes with it.
See: http://manual.audacityteam.org/man/Audacity_Projects
and: http://wiki.audacityteam.org/wiki/Sendi ... _to_others
-- Bill
-- Bill
waxcylinder
Unless you are wanting to deal with multi-track projects than you may find it easier to export WAVs to send to each other.
