Keyboard Yes or No
jaap
Keyboard Yes or No
Post by jaap » Sun May 29, 2011 9:57 am
When using cmd W to close a file ( in Audacity 1.3.13)
a confirmation screen asks "save file or not"
3 answer possibilities No Cancel and Yes
Yes button is active
Just using keyboard "N" for No does not help (no effect)
using TAB does change button shade but Yes button remains active. (on return a new screen opens to name the file)
alt-N has no effect
How to say NO on this confirmation screen using keyboard?
I use audacity 1.3.13
Reason: posts merged and moved to correct forum
Re: Keyboard Yes or No
Post by kozikowski » Sun May 29, 2011 6:10 pm
Try control keys instead of command. Most of the development work is on PCs and sometimes they leave the older control keys lying around.
