100% cpu usage
100% cpu usage
I am getting 100% cpu usage after using 'generate noise'. Is this a bug?
(With 'generate silence' or 'generate chirp' it goes back to 1-2% cpu usage.)
(Audacity 1.3.6a2, Mac OS X 10.4.11)
Re: 100% cpu usage
Bugs are very specific events and they're a lot less common than everybody thinks. Some unintended (usually evil) behavior easily reproducible by the many hundreds of people who reported it.
So chances are, no.
When I do that, my CPU goes up into the high 70% range and then settles back down to normal. Doesn't yours come back down?
So chances are, no.
Re: 100% cpu usage
I don't know if this can be called a bug, maybe not, if no-one else has the problem, but I am not aware of any special configuration with my computer.
It happens when I start audacity, have an empty project and then go to generate noise. The noise track is generated o.k. but the cpu stays at 100%.
After some trying I found that it can happen also with other things from the generate menu, but not necessarily. Also, sometimes with noise it doesn't happen.
I try to upload two images of the output of 'Activity Monitor' one is for the case when cpu load goes back to normal:, the other when it stays high: The difference seems to be the last thread "ODManager", all other threads are obviously yielding cpu time.
Re: 100% cpu usage
<<<The difference seems to be the last thread "ODManager", all other threads are obviously yielding cpu time.>>>
...he said, secure in the knowledge that he was talking to a room full of system level programmers.
He wasn't.
I'll ping one of the forum administrators for you. They could use somebody who speaks OS-X and Process Level.
He wasn't.
- Quality Assurance
Re: 100% cpu usage
You're using an alpha (development) version of Audacity that is now about a month old. ODManager is the process for importing uncompressed files immediately then being able to play or edit them while the waveform summary data is still being loaded. I don't know why it should be called after generating in an empty project, but you should try again with the current a4 alpha:george13 wrote:I am getting 100% cpu usage after using 'generate noise'. Is this a bug?
http://www.audacity.homerow.net/index.p ... .3.6a4.dmg
If there is still a problem then we can look at it in terms of the current code which has changed significantly since the version you are using.
Re: 100% cpu usage
I've downloaded the latest version (1.3.6a4, nightly) yesterday. Unfortunately, it's still there. I found it's not only happening with the generate menu, but also when I start audacity and import a file (wav or mp3) by drag and drop. When importing the same file from the file-import menu cpu-usage doesn't go up. Sometimes the cpu usage goes up only after going to a menu with dialog.
Also I think it happens especially with very short pieces of audio (about 5 secs or so).
This is the thread that I believe is responsible for it (hope that helps):
248 Thread_1403
248 _pthread_body
248 ODManager::ODManagerHelperThread::callback(void*)
248 ODComputeSummaryTask::~ODComputeSummaryTask [in-charge deleting]()
248 Thread_1403
248 _pthread_body
Re: 100% cpu usage
<<<Gale Andrews>>>
You didn't get that note from me, did you? I was posting about this when one of our little forum squalls went through and I think took my message with it.
It's digital, what could go wrong?
Kozx
Kozx
- Quality Assurance
Re: 100% cpu usage
George13: I'll ask our Google Summer of Code student developing "On Demand" for his opinion. If you go Audacity > Preferences > Import / Export and select "Make a copy of uncompressed audio...", does it make any difference?
No I didn't get the PM you said you were going to send, I just happened to be looking. Can you still see your message in "Sent" or "Outbox"?kozikowski wrote:You didn't get that note from me, did you? I was posting about this when one of our little forum squalls went through and I think took my message with it. Koz
Re: 100% cpu usage
No, "Make a copy of uncompressed audio..." doesn't make a difference. In fact, I had this on all the time. Turning it off doesn't make a difference either.
While I'am at it, I also got a crash that's in the "On Demand" part: (Sorry for all the bad news): This is happening when choosing "File - Export" and there Format: "Other FFmpeg-Compatible Files" (the last one) as soon as one clicks on the "options ..." button.
Code: Select all
Date/Time: 2008-07-27 12:02:10.932 +0200
OS Version: 10.4.11 (Build 8S165)
Report Version: 4
Command: Audacity
Path: /Applications/Audio/audacity1.3.6a4/Audacity.app/Contents/MacOS/Audacity
Parent: WindowServer [71]
Version: 1.3.4 (1.3.4)
PID: 527
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_INVALID_ADDRESS (0x0001) at 0xff7ac4fc
Thread 0 Crashed:
0 <<00000000>> 0xff7ac4fc 0 + -8731396
1 net.sourceforge.audacity 0x002700a4 ODPCMAliasBlockFile::IsSummaryBeingComputed() + 35488
2 net.sourceforge.audacity 0x00279744 ODPCMAliasBlockFile::IsSummaryBeingComputed() + 74048
3 net.sourceforge.audacity 0x00238154 BrowserFrame::~BrowserFrame [in-charge deleting]() + 7424
4 com.apple.NavigationServices 0x931eddb8 InvokeNavEventUPP + 24
5 com.apple.NavigationServices 0x931edd68 TNavClient::Event(long) const + 108
6 com.apple.NavigationServices 0x931f8698 TBrowseDialog::DoMouseEvent(OpaqueEventRef*) + 316
7 com.apple.NavigationServices 0x931f6054 TBrowseDialog::EventWindowHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*) + 1172
8 com.apple.NavigationServices 0x931f5b90 TBrowseDialog::EventWindowHandlerDispatch(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 80
9 com.apple.HIToolbox 0x932aa934 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 692
10 com.apple.HIToolbox 0x932aa08c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372
11 com.apple.HIToolbox 0x932b0e90 SendEventToEventTarget + 40
12 com.apple.HIToolbox 0x9333d230 HandleMouseEventForWindow(OpaqueWindowPtr*, OpaqueEventRef*, unsigned short) + 236
13 com.apple.HIToolbox 0x934a03e8 HandleMouseEvent(OpaqueEventRef*) + 368
14 com.apple.HIToolbox 0x932b11fc ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 496
15 com.apple.HIToolbox 0x932aab84 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1284
16 com.apple.HIToolbox 0x932aa08c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372
17 com.apple.HIToolbox 0x932b0e90 SendEventToEventTarget + 40
18 com.apple.HIToolbox 0x932f1c04 ToolboxEventDispatcher + 92
19 com.apple.HIToolbox 0x93390a10 TryEventDispatcher + 108
20 com.apple.HIToolbox 0x93390668 GetOrPeekEvent + 304
21 com.apple.HIToolbox 0x933904c0 GetNextEventMatchingMask + 440
22 com.apple.HIToolbox 0x93390244 WNEInternal + 152
23 com.apple.HIToolbox 0x93390198 WaitNextEvent + 76
24 com.apple.NavigationServices 0x93200b3c TBrowseDialog::EventLoop() + 76
25 com.apple.NavigationServices 0x931f7af4 TBrowseDialog::StartDialog() + 388
26 com.apple.NavigationServices 0x931e5a14 _NavDialog::Run() + 132
27 com.apple.NavigationServices 0x931e5948 NavDialogRun + 64
28 net.sourceforge.audacity 0x002394e8 BrowserFrame::~BrowserFrame [in-charge deleting]() + 12436
29 net.sourceforge.audacity 0x0009d298 EnvPoint::WriteXML(XMLWriter&) + 18676
30 net.sourceforge.audacity 0x000a0d2c EnvPoint::WriteXML(XMLWriter&) + 33672
31 net.sourceforge.audacity 0x000e2030 LangHash::operator[](wxString const&) + 14172
32 net.sourceforge.audacity 0x001cb73c wxAboutDialogCreditItemsListNode::~wxAboutDialogCreditItemsListNode [in-charge deleting]() + 5500
33 net.sourceforge.audacity 0x001306ac AudacityPrintout::~AudacityPrintout [in-charge deleting]() + 2612
34 net.sourceforge.audacity 0x004d49a8 wxStandardPaths::~wxStandardPaths [in-charge]() + 2024
35 net.sourceforge.audacity 0x004d4ba8 wxStandardPaths::~wxStandardPaths [in-charge]() + 2536
36 net.sourceforge.audacity 0x004d4f84 wxStandardPaths::~wxStandardPaths [in-charge]() + 3524
37 net.sourceforge.audacity 0x003d7d8c non-virtual thunk [nv:-452] to wxListBoxBase::~wxListBoxBase [in-charge deleting]() + 10764
38 net.sourceforge.audacity 0x0032c440 wxListCtrl::wxListCtrl[not-in-charge]() + 13136
39 net.sourceforge.audacity 0x00361d64 wxClassInfo::IsKindOf(wxClassInfo const*) const + 32180
40 com.apple.HIToolbox 0x932aa934 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 692
41 com.apple.HIToolbox 0x932aa08c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372
42 com.apple.HIToolbox 0x932b0e90 SendEventToEventTarget + 40
43 com.apple.HIToolbox 0x933297e8 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 380
44 com.apple.HIToolbox 0x933596a0 SendMenuItemSelectedEvent + 136
45 com.apple.HIToolbox 0x933595a8 FinishMenuSelection(MenuData*, MenuData*, MenuResult*, MenuResult*, unsigned long, unsigned long, unsigned long, unsigned char) + 144
46 com.apple.HIToolbox 0x93340a54 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 404
47 com.apple.HIToolbox 0x9334053c MenuSelect + 100
48 net.sourceforge.audacity 0x00357304 wxMacToolTipTimer::Notify() + 10084
49 net.sourceforge.audacity 0x002edffc wxwxAccelListNode::~wxwxAccelListNode [in-charge deleting]() + 11916
50 com.apple.HIToolbox 0x932aa934 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 692
51 com.apple.HIToolbox 0x932aa08c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372
52 com.apple.HIToolbox 0x932b0e90 SendEventToEventTarget + 40
53 com.apple.HIToolbox 0x934a03fc HandleMouseEvent(OpaqueEventRef*) + 388
54 com.apple.HIToolbox 0x932b11fc ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 496
55 com.apple.HIToolbox 0x932aab84 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1284
56 com.apple.HIToolbox 0x932aa08c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372
57 com.apple.HIToolbox 0x932b0e90 SendEventToEventTarget + 40
58 net.sourceforge.audacity 0x002ebb1c wxwxAccelListNode::~wxwxAccelListNode [in-charge deleting]() + 2476
59 net.sourceforge.audacity 0x002ebc0c wxwxAccelListNode::~wxwxAccelListNode [in-charge deleting]() + 2716
60 net.sourceforge.audacity 0x00307f64 wxDropSourceBase::~wxDropSourceBase [in-charge]() + 276
61 net.sourceforge.audacity 0x003a6a80 wxDisplayModule::~wxDisplayModule [in-charge]() + 528
62 net.sourceforge.audacity 0x0037a65c wxANIDecoder::Clone() const + 1004
63 net.sourceforge.audacity 0x00476544 wxHashTable::~wxHashTable [in-charge]() + 3124
64 net.sourceforge.audacity 0x000034b4 0x1000 + 9396
65 net.sourceforge.audacity 0x000023cc 0x1000 + 5068
66 net.sourceforge.audacity 0x000020d0 0x1000 + 4304
Thread 1:
0 libSystem.B.dylib 0x9000b348 mach_msg_trap + 8
1 libSystem.B.dylib 0x9000b29c mach_msg + 60
2 com.apple.CoreFoundation 0x907de9ac __CFRunLoopRun + 832
3 com.apple.CoreFoundation 0x907de2b0 CFRunLoopRunSpecific + 268
4 com.apple.audio.CoreAudio 0x91459524 HALRunLoop::OwnThread(void*) + 264
5 com.apple.audio.CoreAudio 0x914592c4 CAPThread::Entry(CAPThread*) + 96
6 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 2:
0 libSystem.B.dylib 0x900411f8 mach_wait_until + 8
1 libSystem.B.dylib 0x90040fc4 nanosleep + 388
2 net.sourceforge.audacity 0x0000f95c AudioThread::callback(void*) + 124
3 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 3:
0 libSystem.B.dylib 0x90054388 semaphore_timedwait_signal_trap + 8
1 libSystem.B.dylib 0x90070be8 pthread_cond_timedwait_relative_np + 556
2 ...ple.CoreServices.CarbonCore 0x90bf93f4 TSWaitOnSemaphoreCommon + 176
3 ...ickTimeComponents.component 0x9a138804 ReadSchedulerThreadEntryPoint + 5300
4 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 4:
3 ...ple.CoreServices.CarbonCore 0x90c03e9c AIOFileThread(void*) + 520
Thread 5:
0 net.sourceforge.audacity 0x00262820 ODComputeSummaryTask::~ODComputeSummaryTask [in-charge deleting]() + 3340
1 net.sourceforge.audacity 0x00262fe8 ODManager::ODManagerHelperThread::callback(void*) + 20
2 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 6:
0 libSystem.B.dylib 0x9002f08c kevent + 12
1 com.apple.DesktopServices 0x92b07e50 TFSNotificationTask::FSNotificationTaskProc(void*) + 56
2 ...ple.CoreServices.CarbonCore 0x90bc6794 PrivateMPEntryPoint + 76
Thread 7:
0 libSystem.B.dylib 0x9002c3c8 semaphore_wait_signal_trap + 8
1 libSystem.B.dylib 0x90030eac pthread_cond_wait + 480
2 ...ple.CoreServices.CarbonCore 0x90bc6984 MPWaitOnQueue + 224
3 com.apple.DesktopServices 0x92b084cc TNodeSyncTask::SyncTaskProc(void*) + 116
4 ...ple.CoreServices.CarbonCore 0x90bc6794 PrivateMPEntryPoint + 76
5 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 0 crashed with PPC Thread State 64:
srr0: 0x00000000ff7ac4fc srr1: 0x100000004200f030 vrsave: 0x0000000000000000
cr: 0x22022234 xer: 0x0000000000000000 lr: 0x000000000026bbd8 ctr: 0x00000000ff7ac4ff
r0: 0x00000000ff7ac4ff r1: 0x00000000bfffd0b0 r2: 0x000000000ad9c6e0 r3: 0x0000000000000000
r4: 0x0000000000000000 r5: 0x000000000c50ff78 r6: 0x0000000000000001 r7: 0x0000000000000008
r8: 0x0000000000000008 r9: 0x00000000009a7eac r10: 0x000000000c600206 r11: 0x0000000042022232
r12: 0x00000000ff7ac4ff r13: 0x00000000bfffd4ec r14: 0x00000000bfffd4fc r15: 0x00000000bfffd50c
r16: 0x00000000bfffd51c r17: 0x00000000bfffd52c r18: 0x00000000bfffd53c r19: 0x00000000bfffd568
r20: 0x00000000bfffd578 r21: 0x00000000bfffd588 r22: 0x00000000bfffd598 r23: 0x00000000bfffd168
r24: 0x00000000bfffd2d0 r25: 0x0000000000aabba4 r26: 0x00000000bfffd54c r27: 0x00000000bfffd55c
r28: 0x00000000bfffd2d0 r29: 0x0000000000aafd00 r30: 0x000000000c510370 r31: 0x000000000026bba4
Binary Images Description:
0x1000 - 0x97efff net.sourceforge.audacity 1.3.4 /Applications/Audio/audacity1.3.6a4/Audacity.app/Contents/MacOS/Audacity
0xc9c000 - 0xc9efff com.apple.textencoding.unicode 2.0 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0xf4c000 - 0xf4efff net.culater.SIMBL 0.2 (8) /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL
0xff3000 - 0xff3fff MultiInspectorFreeSys.dylib /Library/Audio/Plug-Ins/Components/MultiInspectorFree.component/Contents/MacOS/MultiInspectorFreeSys.dylib
0x1f73000 - 0x1f74fff com.apple.aoa.halplugin 2.5.6 (2.5.6b5) /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
0x1f8f000 - 0x1f8ffff alias_1407.so /Library/Audio/Plug-Ins/LADSPA/alias_1407.so
0x1fa1000 - 0x1fa1fff amp_1181.so /Library/Audio/Plug-Ins/LADSPA/amp_1181.so
0x1fab000 - 0x1facfff am_pitchshift_1433.so /Library/Audio/Plug-Ins/LADSPA/am_pitchshift_1433.so
0x1fb1000 - 0x1fb1fff comb_1190.so /Library/Audio/Plug-Ins/LADSPA/comb_1190.so
0x1fe0000 - 0x1fe0fff comb_splitter_1411.so /Library/Audio/Plug-Ins/LADSPA/comb_splitter_1411.so
0x1fed000 - 0x1ff0fff allpass_1895.so /Library/Audio/Plug-Ins/LADSPA/allpass_1895.so
0x640b000 - 0x640dfff analogue_osc_1416.so /Library/Audio/Plug-Ins/LADSPA/analogue_osc_1416.so
0x6415000 - 0x6415fff const_1909.so /Library/Audio/Plug-Ins/LADSPA/const_1909.so
0x6427000 - 0x6429fff bandpass_a_iir_1893.so /Library/Audio/Plug-Ins/LADSPA/bandpass_a_iir_1893.so
0x642f000 - 0x6431fff bandpass_iir_1892.so /Library/Audio/Plug-Ins/LADSPA/bandpass_iir_1892.so
0x6438000 - 0x6439fff bode_shifter_1431.so /Library/Audio/Plug-Ins/LADSPA/bode_shifter_1431.so
0x643e000 - 0x643ffff bode_shifter_cv_1432.so /Library/Audio/Plug-Ins/LADSPA/bode_shifter_cv_1432.so
0x6455000 - 0x6456fff chebstortion_1430.so /Library/Audio/Plug-Ins/LADSPA/chebstortion_1430.so
0x645b000 - 0x645bfff crossover_dist_1404.so /Library/Audio/Plug-Ins/LADSPA/crossover_dist_1404.so
0x649d000 - 0x64a0fff butterworth_1902.so /Library/Audio/Plug-Ins/LADSPA/butterworth_1902.so
0x64a9000 - 0x64acfff comb_1887.so /Library/Audio/Plug-Ins/LADSPA/comb_1887.so
0x64b8000 - 0x64b8fff dc_remove_1207.so /Library/Audio/Plug-Ins/LADSPA/dc_remove_1207.so
0x64bc000 - 0x64bdfff decay_1886.so /Library/Audio/Plug-Ins/LADSPA/decay_1886.so
0x64c2000 - 0x64c2fff foldover_1213.so /Library/Audio/Plug-Ins/LADSPA/foldover_1213.so
0x64e4000 - 0x64e5fff decimator_1202.so /Library/Audio/Plug-Ins/LADSPA/decimator_1202.so
0x64e9000 - 0x64eafff declip_1195.so /Library/Audio/Plug-Ins/LADSPA/declip_1195.so
0x64ee000 - 0x64f0fff delay_1898.so /Library/Audio/Plug-Ins/LADSPA/delay_1898.so
0x64fa000 - 0x64fcfff delayorama_1402.so /Library/Audio/Plug-Ins/LADSPA/delayorama_1402.so
0x6503000 - 0x6504fff diode_1185.so /Library/Audio/Plug-Ins/LADSPA/diode_1185.so
0x6508000 - 0x6509fff divider_1186.so /Library/Audio/Plug-Ins/LADSPA/divider_1186.so
0x650e000 - 0x6510fff dj_eq_1901.so /Library/Audio/Plug-Ins/LADSPA/dj_eq_1901.so
0x6518000 - 0x6519fff dj_flanger_1438.so /Library/Audio/Plug-Ins/LADSPA/dj_flanger_1438.so
0x651e000 - 0x6520fff dyson_compress_1403.so /Library/Audio/Plug-Ins/LADSPA/dyson_compress_1403.so
0x6527000 - 0x6528fff fad_delay_1192.so /Library/Audio/Plug-Ins/LADSPA/fad_delay_1192.so
0x652d000 - 0x652efff fast_lookahead_limiter_1913.so /Library/Audio/Plug-Ins/LADSPA/fast_lookahead_limiter_1913.so
0x6534000 - 0x6535fff flanger_1191.so /Library/Audio/Plug-Ins/LADSPA/flanger_1191.so
0x653b000 - 0x653dfff fm_osc_1415.so /Library/Audio/Plug-Ins/LADSPA/fm_osc_1415.so
0x6544000 - 0x6544fff foverdrive_1196.so /Library/Audio/Plug-Ins/LADSPA/foverdrive_1196.so
0x6548000 - 0x6549fff freq_tracker_1418.so /Library/Audio/Plug-Ins/LADSPA/freq_tracker_1418.so
0x654e000 - 0x654ffff gate_1410.so /Library/Audio/Plug-Ins/LADSPA/gate_1410.so
0x6555000 - 0x6556fff giant_flange_1437.so /Library/Audio/Plug-Ins/LADSPA/giant_flange_1437.so
0x6599000 - 0x659dfff gong_1424.so /Library/Audio/Plug-Ins/LADSPA/gong_1424.so
0x65a9000 - 0x65aafff gong_beater_1439.so /Library/Audio/Plug-Ins/LADSPA/gong_beater_1439.so
0x65af000 - 0x65bffff gsm_1215.so /Library/Audio/Plug-Ins/LADSPA/gsm_1215.so
0x65d6000 - 0x65d9fff gverb_1216.so /Library/Audio/Plug-Ins/LADSPA/gverb_1216.so
0x65e2000 - 0x65e2fff hard_limiter_1413.so /Library/Audio/Plug-Ins/LADSPA/hard_limiter_1413.so
0x65e7000 - 0x65e8fff harmonic_gen_1220.so /Library/Audio/Plug-Ins/LADSPA/harmonic_gen_1220.so
0x65ed000 - 0x65effff highpass_iir_1890.so /Library/Audio/Plug-Ins/LADSPA/highpass_iir_1890.so
0x65f5000 - 0x65f5fff hilbert_1440.so /Library/Audio/Plug-Ins/LADSPA/hilbert_1440.so
0x65f9000 - 0x65f9fff impulse_1885.so /Library/Audio/Plug-Ins/LADSPA/impulse_1885.so
0x6705000 - 0x670cfff hermes_filter_1200.so /Library/Audio/Plug-Ins/LADSPA/hermes_filter_1200.so
0x671c000 - 0x67dbfff imp_1199.so /Library/Audio/Plug-Ins/LADSPA/imp_1199.so
0x6842000 - 0x6842fff inv_1429.so /Library/Audio/Plug-Ins/LADSPA/inv_1429.so
0x6846000 - 0x6846fff karaoke_1409.so /Library/Audio/Plug-Ins/LADSPA/karaoke_1409.so
0x684a000 - 0x684afff latency_1914.so /Library/Audio/Plug-Ins/LADSPA/latency_1914.so
0x684e000 - 0x684ffff lcr_delay_1436.so /Library/Audio/Plug-Ins/LADSPA/lcr_delay_1436.so
0x6856000 - 0x6858fff lowpass_iir_1891.so /Library/Audio/Plug-Ins/LADSPA/lowpass_iir_1891.so
0x685e000 - 0x685ffff ls_filter_1908.so /Library/Audio/Plug-Ins/LADSPA/ls_filter_1908.so
0x6865000 - 0x6865fff matrix_ms_st_1421.so /Library/Audio/Plug-Ins/LADSPA/matrix_ms_st_1421.so
0x6869000 - 0x686afff matrix_spatialiser_1422.so /Library/Audio/Plug-Ins/LADSPA/matrix_spatialiser_1422.so
0x686f000 - 0x686ffff matrix_st_ms_1420.so /Library/Audio/Plug-Ins/LADSPA/matrix_st_ms_1420.so
0x6873000 - 0x6873fff mod_delay_1419.so /Library/Audio/Plug-Ins/LADSPA/mod_delay_1419.so
0x6877000 - 0x6878fff multivoice_chorus_1201.so /Library/Audio/Plug-Ins/LADSPA/multivoice_chorus_1201.so
0x687f000 - 0x6881fff notch_iir_1894.so /Library/Audio/Plug-Ins/LADSPA/notch_iir_1894.so
0x6888000 - 0x688afff phasers_1217.so /Library/Audio/Plug-Ins/LADSPA/phasers_1217.so
0x6893000 - 0x6896fff plate_1423.so /Library/Audio/Plug-Ins/LADSPA/plate_1423.so
0x689f000 - 0x689ffff pointer_cast_1910.so /Library/Audio/Plug-Ins/LADSPA/pointer_cast_1910.so
0x68a4000 - 0x68a4fff rate_shifter_1417.so /Library/Audio/Plug-Ins/LADSPA/rate_shifter_1417.so
0x68a8000 - 0x68a9fff retro_flange_1208.so /Library/Audio/Plug-Ins/LADSPA/retro_flange_1208.so
0x68b1000 - 0x68b2fff revdelay_1605.so /Library/Audio/Plug-Ins/LADSPA/revdelay_1605.so
0x68b8000 - 0x68b9fff ringmod_1188.so /Library/Audio/Plug-Ins/LADSPA/ringmod_1188.so
0x68bf000 - 0x68c0fff satan_maximiser_1408.so /Library/Audio/Plug-Ins/LADSPA/satan_maximiser_1408.so
0x68c5000 - 0x68c7fff sc1_1425.so /Library/Audio/Plug-Ins/LADSPA/sc1_1425.so
0x68cf000 - 0x68d1fff sc2_1426.so /Library/Audio/Plug-Ins/LADSPA/sc2_1426.so
0x68d9000 - 0x68dbfff sc3_1427.so /Library/Audio/Plug-Ins/LADSPA/sc3_1427.so
0x68e3000 - 0x68e5fff sc4_1882.so /Library/Audio/Plug-Ins/LADSPA/sc4_1882.so
0x68ee000 - 0x68f0fff sc4m_1916.so /Library/Audio/Plug-Ins/LADSPA/sc4m_1916.so
0x68f9000 - 0x68fbfff se4_1883.so /Library/Audio/Plug-Ins/LADSPA/se4_1883.so
0x6904000 - 0x6904fff shaper_1187.so /Library/Audio/Plug-Ins/LADSPA/shaper_1187.so
0x6908000 - 0x690cfff sifter_1210.so /Library/Audio/Plug-Ins/LADSPA/sifter_1210.so
0x6914000 - 0x6914fff sin_cos_1881.so /Library/Audio/Plug-Ins/LADSPA/sin_cos_1881.so
0x6919000 - 0x691afff single_para_1203.so /Library/Audio/Plug-Ins/LADSPA/single_para_1203.so
0x6920000 - 0x6920fff sinus_wavewrapper_1198.so /Library/Audio/Plug-Ins/LADSPA/sinus_wavewrapper_1198.so
0x6924000 - 0x6924fff smooth_decimate_1414.so /Library/Audio/Plug-Ins/LADSPA/smooth_decimate_1414.so
0x6928000 - 0x6928fff split_1406.so /Library/Audio/Plug-Ins/LADSPA/split_1406.so
0x692c000 - 0x692dfff step_muxer_1212.so /Library/Audio/Plug-Ins/LADSPA/step_muxer_1212.so
0x6932000 - 0x6932fff surround_encoder_1401.so /Library/Audio/Plug-Ins/LADSPA/surround_encoder_1401.so
0x6937000 - 0x6938fff svf_1214.so /Library/Audio/Plug-Ins/LADSPA/svf_1214.so
0x693d000 - 0x693efff tape_delay_1211.so /Library/Audio/Plug-Ins/LADSPA/tape_delay_1211.so
0x6944000 - 0x6945fff transient_1206.so /Library/Audio/Plug-Ins/LADSPA/transient_1206.so
0x694a000 - 0x694cfff triple_para_1204.so /Library/Audio/Plug-Ins/LADSPA/triple_para_1204.so
0x6953000 - 0x6954fff valve_1209.so /Library/Audio/Plug-Ins/LADSPA/valve_1209.so
0x6959000 - 0x695afff valve_rect_1405.so /Library/Audio/Plug-Ins/LADSPA/valve_rect_1405.so
0x695f000 - 0x6961fff vynil_1905.so /Library/Audio/Plug-Ins/LADSPA/vynil_1905.so
0x696b000 - 0x696bfff wave_terrain_1412.so /Library/Audio/Plug-Ins/LADSPA/wave_terrain_1412.so
0x696f000 - 0x6970fff xfade_1915.so /Library/Audio/Plug-Ins/LADSPA/xfade_1915.so
0x6975000 - 0x6975fff zm1_1428.so /Library/Audio/Plug-Ins/LADSPA/zm1_1428.so
0x698b000 - 0x698ffff vst-bridge.so /Applications/Audio/audacity1.3.6a4/plug-ins/vst-bridge.so
0x6d47000 - 0x6f99fff org.perian.Perian 1.1 /Library/QuickTime/Perian.component/Contents/MacOS/Perian
0x707b000 - 0x70bafff com.apple.QuickTimeFireWireDV.component 7.5 (861) /System/Library/QuickTime/QuickTimeFirewireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x70c5000 - 0x713ffff com.apple.applepixletvideo 1.2.16 (1.2d16) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x714c000 - 0x7385fff net.telestream.wmv.import 2.2.0.49 /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
0x73bb000 - 0x756ffff net.telestream.wmv.advanced 2.2.0.49 /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
0x8b0a000 - 0x8b49fff com.yohng.W1 ??? (1.0.0) /Library/Audio/Plug-Ins/Components/W1.component/Contents/MacOS/W1
0x8b87000 - 0x8b9bfff nz.net.mnorris.audiounit.Chorus 1.0 /Library/Audio/Plug-Ins/Components/Chorus.component/Contents/MacOS/Chorus
0x8ba9000 - 0x8bbefff nz.net.mnorris.audiounit.CombFilterBank 1.0 /Library/Audio/Plug-Ins/Components/CombFilterBank.component/Contents/MacOS/CombFilterBank
0x8bcd000 - 0x8bebfff com.mda-vst.AudioUnits 1.0.2 /Library/Audio/Plug-Ins/Components/mda.component/Contents/MacOS/mda
0x8bf5000 - 0x8c0afff nz.net.mnorris.audiounit.MrFilterbank 1.0 /Library/Audio/Plug-Ins/Components/MrFilterbank.component/Contents/MacOS/MrFilterbank
0x8c18000 - 0x8c2cfff nz.net.mnorris.audiounit.GrainStreamer 1.0 /Library/Audio/Plug-Ins/Components/GrainStreamer.component/Contents/MacOS/GrainStreamer
0x9870000 - 0x9886fff nz.net.mnorris.audiounit.IdeeFixer 1.0 /Library/Audio/Plug-Ins/Components/IdeeFixer.component/Contents/MacOS/IdeeFixer
0x9896000 - 0x98dafff com.vertexdsp.audiounit.MultiInspectorFree ??? (1.0) /Library/Audio/Plug-Ins/Components/MultiInspectorFree.component/Contents/MacOS/MultiInspectorFree
0x9922000 - 0x9965fff com.quikquak.pitchwheel.au.1.1.0 ??? (1.1.0) /Library/Audio/Plug-Ins/Components/Pitchwheel.component/Contents/MacOS/Pitchwheel
0x9980000 - 0x9993fff com.apple.audiounit.RIAA 1.0 /Library/Audio/Plug-Ins/Components/RIAA.component/Contents/MacOS/RIAA
0x99a8000 - 0x99befff nz.net.audiounit.SpectralAveraging 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralAveraging.component/Contents/MacOS/MNSpectralAveraging
0x99cd000 - 0x99e3fff nz.net.audiounit.SpectralBlurring 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralBlurring.component/Contents/MacOS/MNSpectralBlurring
0x99f3000 - 0x9a2ffff com.DFP.fish.fillets ??? (0.0.1d1) /Library/Audio/Plug-Ins/Components/FishFillets.component/Contents/MacOS/FishFillets
0x9a6c000 - 0x9a88fff nz.net.audiounit.SpectralEmergence 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralEmergence.component/Contents/MacOS/MNSpectralEmergence
0x9a98000 - 0x9aaefff nz.net.audiounit.SpectralFilterbank 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralFilterbank.component/Contents/MacOS/MNSpectralFilterbank
0x9abe000 - 0x9ad4fff nz.net.audiounit.SpectralFreezing 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralFreezing.component/Contents/MacOS/MNSpectralFreezing
0x9ae3000 - 0x9afafff nz.net.audiounit.SpectralGlidingFilters 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralGlidingFilters.component/Contents/MacOS/MNSpectralGlidingFilters
0x9b0a000 - 0x9b21fff nz.net.audiounit.SpectralGranulation 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralGranulation.component/Contents/MacOS/MNSpectralGranulation
0x9b31000 - 0x9b49fff nz.net.audiounit.SpectralGateAndHold 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralGateAndHold.component/Contents/MacOS/MNSpectralGateAndHold
0x9b59000 - 0x9b70fff nz.net.audiounit.SpectralHarmonizer 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralHarmonizer.component/Contents/MacOS/MNSpectralHarmonizer
0x9b80000 - 0x9b99fff nz.net.audiounit.SpectralDroneMaker 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralDroneMaker.component/Contents/MacOS/MNSpectralDroneMaker
0x9baa000 - 0x9bc0fff nz.net.audiounit.SpectralPartialGlide 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralPartialGlide.component/Contents/MacOS/MNSpectralPartialGlide
0x9bd0000 - 0x9be6fff nz.net.audiounit.SpectralPitchShift 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralPitchShift.component/Contents/MacOS/MNSpectralPitchShift
0x9bf5000 - 0x9c0bfff nz.net.audiounit.SpectralPulsing 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralPulsing.component/Contents/MacOS/MNSpectralPulsing
0x9c1a000 - 0x9c31fff nz.net.audiounit.SpectralStretch 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralStretch.component/Contents/MacOS/MNSpectralStretch
0x9c41000 - 0x9c57fff nz.net.audiounit.SpectralShuffle 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralShuffle.component/Contents/MacOS/MNSpectralShuffle
0x9c66000 - 0x9c7cfff nz.net.audiounit.SpectralBinShift 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralBinShift.component/Contents/MacOS/MNSpectralBinShift
0x9c8c000 - 0x9ca3fff nz.net.audiounit.SpectralShimmer 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralShimmer.component/Contents/MacOS/MNSpectralShimmer
0x9cb3000 - 0x9ccafff nz.net.audiounit.SpectralTracing 1.0 /Library/Audio/Plug-Ins/Components/MNSpectralTracing.component/Contents/MacOS/MNSpectralTracing
0x9cda000 - 0x9d0dfff com.quikquak.upstereo.au.1.0.1 ??? (1.0.1) /Library/Audio/Plug-Ins/Components/UpStereo.component/Contents/MacOS/UpStereo
0x9d23000 - 0xa109fff com.voxengo.audio-plugins.audiounit.OvertoneGEQ 1.4 /Library/Audio/Plug-Ins/Components/Overtone GEQ.component/Contents/MacOS/Overtone GEQ
0xa1d7000 - 0xa1effff com.masseyplugins.audiounit.TapeHead 1.0.0 /Library/Audio/Plug-Ins/Components/TapeHeadMedium.component/Contents/MacOS/TapeHeadMedium
0xa505000 - 0xa517fff com.wa.sounds.gain ??? (1.0.0) /Library/Audio/Plug-Ins/Components/gain.component/Contents/MacOS/gain
0xa65d000 - 0xa66dfff com.wa.sounds.rider ??? (1.0) /Library/Audio/Plug-Ins/Components/rider.component/Contents/MacOS/rider
0xacd2000 - 0xacd5fff com.apple.CarbonSpellChecker 1.0 /System/Library/CoreServices/CarbonSpellChecker.bundle/Contents/MacOS/CarbonSpellChecker
0xacd9000 - 0xacddfff com.apple.CommonCocoaPanels 2.0 (10) /System/Library/CoreServices/CommonCocoaPanels.bundle/Contents/MacOS/CommonCocoaPanels
0x70000000 - 0x700fdfff com.apple.audio.units.Components 1.4.7 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8f8c0000 - 0x8f961fff com.apple.QuickTimeImporters.component 7.5 (861) /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x8fe00000 - 0x8fe52fff dyld 46.16 /usr/lib/dyld
0x90000000 - 0x901bcfff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x90214000 - 0x90219fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x9021b000 - 0x90268fff com.apple.CoreText 1.0.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90293000 - 0x90344fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90373000 - 0x9072efff com.apple.CoreGraphics 1.258.78 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x907bb000 - 0x90895fff com.apple.CoreFoundation 6.4.11 (368.35) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x908de000 - 0x908defff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x908e0000 - 0x909e2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a3c000 - 0x90ac0fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90aea000 - 0x90b5cfff IOKit /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90b72000 - 0x90b84fff libauto.dylib /usr/lib/libauto.dylib
0x90b8b000 - 0x90e62fff com.apple.CoreServices.CarbonCore 681.17 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90ec8000 - 0x90f48fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90f92000 - 0x90fd4fff com.apple.CFNetwork 129.22 (129.23) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90fe9000 - 0x91001fff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91011000 - 0x91092fff com.apple.SearchKit 1.0.7 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x910d8000 - 0x91101fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91112000 - 0x91120fff libz.1.dylib /usr/lib/libz.1.dylib
0x91123000 - 0x912defff com.apple.security 4.6 (29770) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913dd000 - 0x913e6fff com.apple.DiskArbitration 2.1.2 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x913ed000 - 0x913f5fff libbsm.dylib /usr/lib/libbsm.dylib
0x913f9000 - 0x91421fff com.apple.SystemConfiguration 1.8.3 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91434000 - 0x9143ffff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x91444000 - 0x914bffff com.apple.audio.CoreAudio 3.0.5 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x914fc000 - 0x914fcfff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x914fe000 - 0x91536fff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91551000 - 0x91623fff com.apple.ColorSync 4.4.10 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91676000 - 0x91707fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9174e000 - 0x91805fff com.apple.QD 3.10.25 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91842000 - 0x918a0fff com.apple.HIServices 1.5.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x918cf000 - 0x918f0fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91904000 - 0x91929fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x9193c000 - 0x9197efff com.apple.LaunchServices 183 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9199a000 - 0x919aefff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x919bc000 - 0x91a02fff com.apple.ImageIO.framework 1.5.7 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91a19000 - 0x91ae0fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91b2e000 - 0x91b43fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91b48000 - 0x91b66fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91b6c000 - 0x91c23fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91c72000 - 0x91c76fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91c78000 - 0x91ce2fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91ce7000 - 0x91d24fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91d2b000 - 0x91d45fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91d4a000 - 0x91d4dfff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91d4f000 - 0x91e3dfff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x91e5c000 - 0x91e5cfff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91e5e000 - 0x91f43fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91f4b000 - 0x91f6afff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91fd6000 - 0x92044fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9204f000 - 0x920e4fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x920fe000 - 0x92686fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x926b9000 - 0x929e4fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92a14000 - 0x92b02fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92b05000 - 0x92b8dfff com.apple.DesktopServices 1.3.7 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x92bce000 - 0x92df9fff com.apple.Foundation 6.4.10 (567.37) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92f26000 - 0x92f44fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92f4f000 - 0x92fa9fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92fc7000 - 0x92fc7fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92fc9000 - 0x92fddfff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92ff5000 - 0x93005fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x93011000 - 0x93026fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93038000 - 0x930bffff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x930d3000 - 0x930defff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x930e8000 - 0x93115fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x9312f000 - 0x9313efff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9314a000 - 0x931b0fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x931e1000 - 0x93230fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9325e000 - 0x9327bfff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9328d000 - 0x9329afff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x932a3000 - 0x935b1fff com.apple.HIToolbox 1.4.10 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93701000 - 0x9370dfff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x937a7000 - 0x937a7fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x937a9000 - 0x93ddcfff com.apple.AppKit 6.4.10 (824.48) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x94169000 - 0x941dbfff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x94214000 - 0x942d9fff com.apple.audio.toolbox.AudioToolbox 1.4.7 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9432c000 - 0x9432cfff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9432e000 - 0x944eefff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x94538000 - 0x94575fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
0x9457d000 - 0x945cdfff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x945d6000 - 0x945f1fff com.apple.CoreVideo 1.4.2 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x94602000 - 0x94624fff libmx.A.dylib /usr/lib/libmx.A.dylib
0x947c7000 - 0x947d6fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x947de000 - 0x947ebfff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x94831000 - 0x9484afff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x94851000 - 0x94b7dfff com.apple.QuickTime 7.5.0 (861) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94c64000 - 0x94cd5fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x95c24000 - 0x95ce2fff com.apple.WebKit 4525.18 /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x95d50000 - 0x95e38fff com.apple.JavaScriptCore 4525.18 /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x95e74000 - 0x96546fff com.apple.WebCore 4525.18.1 /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x97d4d000 - 0x97d6cfff com.apple.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x98572000 - 0x9857ffff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x9a121000 - 0x9af3cfff com.apple.QuickTimeComponents.component 7.5 (861) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x9b1a1000 - 0x9b1a5fff com.apple.QuickTimeH264.component 7.5 (861) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
Model: PowerMac8,1, BootROM 5.2.2f4, 1 processors, PowerPC G5 (3.0), 1.6 GHz, 2 GB
Graphics: GeForce FX 5200, GeForce FX 5200, AGP, 64 MB
Memory Module: DIMM0/J4000, 1 GB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM1/J4001, 1 GB, DDR SDRAM, PC3200U-30330
Modem: Jump, V.92, Version 1.0
Network Service: Ethernet (integriert), Ethernet, en0
Network Service: Ethernet-Anschluss (en1), Ethernet, en1
Serial ATA Device: ST3320620AS, 298.09 GB
Parallel ATA Device: MATSHITACD-RW CW-8123
USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
USB Device: USB Device, Up to 1.5 Mb/sec, 100 mA
USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
Re: 100% cpu usage
Hi george13,
I'm the student developer Gale was referring to.
Thanks for posting those screenshots; I was able to eliminate a minor bug. The ODManager's thread is not supposed to be created until it is needed. It was being created for things like "generate noise", when it shouldn't. However, when it is running, it sleeps very often if it is idle. When I did the steps "Open Audacity/Generate Noise (3s)" My CPU usage was around 6% once the noise was created, after a 60% peak while the noise was being generated, so it looks more like Koz's.
I noticed you also had an ODComputeSummaryTask running in the "benign" png. This usually means you loaded a file with import/open/dragndrop, although it looks like you're suggesting this is the idle state before you anything in audacity. If you haven't loaded some files and yet the ODComputeSummaryTask is running, then this definitely is a bug; it would be a big help if you could verify your steps for me.
While the file loads, have you been seeing the striped blocks?
Also, how fast is your computer?
Anyway, I fixed this bug and am checking in today.
Looking into this export crash.
Thanks for you help. I'll be watching this thread today.
