If the CD is an exact copy of the LP (no compression, EQ etc.), no-one can tell the difference in a proper double-blind ABX test with properly matched levels and if the two are perfectly in sync. The trouble is that most CD "remasters" have been processed to make them sound louder. Some like this, some don't. Which is right? The LP mastering process has severe limitations, so a CD properly remastered from the master tapes with CD in mind could potentially sound "better", or at least closer to what the artist and producer intended.khoffcran wrote: Or, perhaps, do you suspect - as I do - that almost no audiophiles or even musicians could differentiate between a CD and (clean) vinyl in a blind A/B test?
-- Bill
