audacity doesn't pick up sound
alexfsu
Post by alexfsu » Thu Nov 18, 2010 5:29 am
audacity reads my sound card (apogee duet), but nothing comes into audacity, it's just a flat line..please help!
billw58
Re: audacity doesn't pick up sound
Post by billw58 » Thu Nov 18, 2010 5:55 am
Please don't post the same question in multiple forums. It doesn't get you answers any quicker.
What version of Audacity are you running? We can't tell, because you posted in the 1.2.x and 1.3.x forums.
What Mac and version of OS X are you running?
How do you mean Audacity is "reading" your sound card?
-- Bill
alexfsu
Post by alexfsu » Thu Nov 18, 2010 6:01 am
tried 1.2 and 1.3. newest update of snow leopard, macbook pro. audacity sees the apogee duet. but when i play any sound on my mac, audacity doesn't pick up anything...the monitor reads 0 db's.....when i say "read" i mean i can pick it from the drop down menus for audacity's recording and playing
billw58
Post by billw58 » Thu Nov 18, 2010 3:58 pm
alexfsu wrote:but when i play any sound on my mac, audacity doesn't pick up anything...the monitor reads 0 db's.....when i say "read" i mean i can pick it from the drop down menus for audacity's recording and playing
So you are trying to pick up the sound coming out the speakers? For example, record the sound of a YouTube video? If so, you external interface will not help with that. You need to install SoundFlower.
So Koz's comment in the 1.2.x forum if what you are trying to do is send sound into your Mac through the interface.
BTW, 1.2.x is not recommended for Snow Leopard.
-- Bill
dannyb45
Post by dannyb45 » Tue Nov 23, 2010 10:34 pm
my audacity used to work fine. I've upgraded my computer (dual G5, to OSX 10.5.8 and Audacity to 1.3.12). Now when I try to record by pushing the red dot button the pause button highlights as well and nothing happens. Absolutely nothing. No line, no sound, no nothing. If I push the pause button to try to make it stop pausing, nothing happens. I've checked and my Midi is set as per your instructions. The turntable is picking up the sound because I have the regular audio line connected to my receiver/amp and I can hear it perfectly .... but nothing comes thru the computer.
billw58
Post by billw58 » Tue Nov 23, 2010 10:42 pm
Please don't hijack someone else's thread. In the future, please start a new thread to discuss you problem.
dannyb45 wrote:Now when I try to record by pushing the red dot button the pause button highlights as well and nothing happens. Absolutely nothing. No line, no sound, no nothing. If I push the pause button to try to make it stop pausing, nothing happens.
Check the Transport menu - you probably have sound activated recording checked.
dannyb45 wrote:I've checked and my Midi is set as per your instructions.
Do you mean Apple's Audio Midi Setup application?
dannyb45 wrote:The turntable is picking up the sound because I have the regular audio line connected to my receiver/amp and I can hear it perfectly .... but nothing comes thru the computer.
Is this a USB turntable? You have set the "USB Audio Codec" as the input in Audio Midi Setup? Have you gone to Audacity > Preferences, Devices section and set the USB Audio Codec as the recording device?
-- Bill
dannyb45
Post by dannyb45 » Tue Nov 23, 2010 11:02 pm
I don't know what the Transport menu is ....
Yes, the Midi is set up for USB Audio CODEC as are the preferences in Audacity
I'm using an ION USB turntable
Looking under the Mac system prefs under "sound" I can see that the machine hears the music (i can see the imput levels moving) under the USB Audio CODEC selection
Sorry about the "hijacking", I didn't see a selection to start a new question ...
Post by steve » Tue Nov 23, 2010 11:42 pm
dannyb45 wrote:I don't know what the Transport menu is ....
It's the menu at the top of the main Audacity window that says "Transport".
If that menu is not there, you probably do not have Audacity 1.3.x (This is the forum for Audacity 1.3.x on Mac OS X).
Look in the Audacity Help menu, select "About Audacity" and it will say which version of Audacity you are using.
To find the appropriate place to post, start at the "Board Index" page, then find the appropriate section for you Audacity version and operating system. That will take you to a page with a button that says "NEW TOPIC".
