Music Shrinkage?
jenevans
Music Shrinkage?
Post by jenevans » Thu Nov 04, 2010 2:37 pm
I edited a song and had it the exact right length that I needed it, but it was really loud. So I decreased the volume and it shortened the song, by a lot! The same content is still there, I just decreased the dBs.... Help Please!! I need this song for a project that's due today!
Re: Music Shrinkage?
Post by kozikowski » Thu Nov 04, 2010 3:42 pm
Did you use Effect > Amplify to reduce the volume?
bgravato
Operating System: Linux Debian
Post by bgravato » Fri Nov 05, 2010 12:44 am
Reducing the volume (amplify effect) shouldn't change the duration of the track... unless you used a different effect...
Which audacity version are you using?
Post by kozikowski » Fri Nov 05, 2010 3:13 am
<<<unless you used a different effect...>>>
Or didn't use any effect....
